Tillage with an 850
/ Tillage with an 850 #1
Coles
A couple of years ago I bought an 850 from the original owner's widow. It had less than 200 hrs. on it. It has a front end loader and turf tires front and back. It has worked fine for mowing. Now I am wanting to plow and disk garden space. I'm considering buying new ag tires for the rear (and mounting them on their own rims) and adding rear weights. I would be pulling a small moldboard plow in fairly heavy clay. Has anyone had any luck using an 850 for tillage like this? Or should I start looking for a bigger tractor?
/ Tillage with an 850 #2
A rototiller works fine with turf tires.
Putting a 5' tiller on your 850 may be an option..
/ Tillage with an 850 #3
Turf tires will work fine for the limited use it sounds like you need them for. Ag tires are better if the ground if wet and muddy. On dry ground, the kind you want to work anyway, the turfs will surprise you. I would at least try the turfs first and see how they work before spending any money on ag tires that will not get used much. I'll bet you will be satisfied with the turfs. Good luck.
/ Tillage with an 850 #4
If your tractor is two wheel drive it will be alright to swap to R1s on the rear. If you have 4wd, it wouldn't be a good idea. The front and rear tires are chosen as a set so that they provide a specific ratio. If it is off very much it will put to much stress on your front end.
/ Tillage with an 850 #5
Tire chains might be an option. But if a tiler give the desired results, it is really nice and would work nicely on that machine.
/ Tillage with an 850 #6
I have a two-wheel drive 950 with turf tires that does a good job of pulling a 6 foot disk. I have been pleased at how well it works in dry "workable" ground. Of course they stink if in mud, but then I don't work the ground when it is wet.
/ Tillage with an 850 #7
My 750 does just fine with ag tires pulling a singlebottom plow 12'' for a compact tractor. rear tires loaded with 25gals of water and noburst no-toxic antifreeze
/ Tillage with an 850 #8
My 650 tilled great with a 50" tiller. I don't think you will have any problem with a 850 tilling.
2014 FREIGHTLINER SPRINTER 2500 4X2 CARGO VAN (A59909)
2014 FREIGHTLINER...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59908)
2016 INTERNATIONAL...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2020 John Deere 1770NT Planter (A63109)
2020 John Deere...
Stainless Ice Maker (A61166)
Stainless Ice...
UNUSED WOLVERINE 3PT QUICK HITCH ADAPTER (A62130)
UNUSED WOLVERINE...
