tightening sway chains
   / tightening sway chains #1
Ginormous
Dayton, Ohio
Yanmar YM2210
When I mowed with my new 2210 the other day, I noticed that the 3-pt mower had a lot of range of motion depending on which way the ground sloped. I think the sway chains (part E in Hoye's 3-pt hitch part kit) weren't tight enough. I tightened them up as much as they would go, but the 3-pt mower still can sway back and forth about 6 inches, which isn't bad,but I can't get them as tight as the ones are on my 1700. Any comments on how tight these can/should be?
   / tightening sway chains #2
I don't know what the doctor ordered but I keep mine real snug. It has always worked fine for me. :thumbsup:
   / tightening sway chains #3
On mine, the threaded ends will very nearly touch inside the turnbuckle. If you've gotten it tightened to that point and it still isn't tight enough, you will have to change something.
On my YM2000, the anchor for the chains is outside the mount for the lift arm, so restricts the lift arm from swinging toward the middle of the tractor. I don't know how the 2210 is set up; a couple other machines have the chains mounted on the center of the tractor.
Moving the implement's lift pins so they point inward moves the arms closer to the center of the tractor, and will take up the slack (at least to some degree) you're experiencing. If the chains mount to the center of the tractor, put the pins pointing to the outside.
I run the chains on my mower snug. I don't like the mower banging around 6 or 7 feet behind the axle.
   / tightening sway chains #4
My neighbor the real farmer (3rd generation orchardist) advised keep sway chains as tight as possible so the tractor and implement move as a single, long piece of equipment. This is especially important working around trees because it is easy for a randomly swinging implement to gouge a tree.
   / tightening sway chains #5
It will help if you raise the mower and snug up those chains. If there's too much tension on the chains when it's raised, estimate how much sway you have (when raised), lower it and snug the chains again until you get the minimum side to side sway...but you won't eliminate all of it.
This works with mowers...with ground engaging implements, you're better off with some sway.
   / tightening sway chains #6
The sway chains on my YM1810D did not have enough travel so as to prevent excessive side to side movement. Impossible to plow with. The lower lift arms were swaying unchecked and hitting the tires. I had to drill an additional hole in each lift arm to relocate the sway chain attaching bolts. Not a big deal. The chains supplied by Fredericks were obviously brand new, but I suspect they are for a full size tractor - not a CUT. Anyway, the lift arms are easy to remove. I used a 1/2" bit in a drill press to do the drilling. Worked out fine. It might have been easier to just remove a link from each sway chain. Would have done the same thing.
   / tightening sway chains #7
Like roy said, raise it up then tighten. Depending on where they fasten to your tractor, you make break your chains when you raise lift if you tighten em with implement lowered.
Thanks everybody! I thought tighter would be better, but it's good to hear advice from people who have been down this road already. :thumbsup:
   / tightening sway chains #9
Yea 6"s is way to much, i barely have maybe 10" at most if there all the way loose and i push the bush hog to the side. 6"s sounds like not much taken up.I have a ym2000. One of my shakles fell out while mowing as the pin got pulled and it fell out. I could not find anything local that would tread into the turnbuckle as i lost that end as well by not taking it off. Anyway when i ordered some stuff i just got one from hoye for like $20. Its much better than the original as it has a handle to turn like a big tractor. You could probly call up frederics and just request a new set and they will probly help you out.
   / tightening sway chains #10
My Yanmars have the sway mount points in the same plane as the lift arm pivots. I think Ginormous' 2210 is the same. With this geometry, the chains shouldn't be tighter raised or lowered. But tightness should certainly be checked before use.
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
