Tightening bar nuts
/ Tightening bar nuts #1
Giles
Florence Alabama
2009 Kubota B2320---Wheelhorse lawn mower--- Case 480D Backhoe
I had a young man bring his Stihl Ms390 chainsaw to me for a muffler mod and carb work.
I had to use a long 3/8 pull handle to remove the bar nuts.
I talked with him when I finished and he said the chain would continuously loosen up if he didn't.
He was not lifting the end of bar and would sometimes back off the tension screw.
Four days later, he stopped by to thank me, said it was a different saw and the chain stayed tight with only occasional tightening.
I have run into this many times and replaced many bar studs that were broken, stripped or pulled out!
/ Tightening bar nuts #5
My saw only has one nut :(
Many saws do, even the Stihl 200t and the 201t, have only one nut. If you look at them, bars are limited in movement by a key that fits in the bar center slot. Some saws will have a small round pin.
Most bars with two nuts are limited by the two studs.
/ Tightening bar nuts #7
A lot of people clobber the bar nuts. I don't even use the full leverage of the scrench tool -- almost always choke up on it to be sure I'm just snugging the nuts.
Another problem I hear of often, is someone with a worn drive sprocket can't get the chain to stay tight and then do all sorts of other things fighting the problem.
/ Tightening bar nuts #8
I had to use a breaker bar not long ago to break loose and dang spark plug.
Seen many plastic cases saws with the bar studs pulled through from folks over tightening.
Alot of folks dont know how to do a proper chain tension like you stated Giles.
/ Tightening bar nuts #9
Universal torque specification: Tighten until threads begin to strip, then loosen one half turn.
I was cleaning my old Super XL/AO for storage this morning and thought to myself how well those nuts stayed set when not even turned in that tight. I was eighteen years-young when I bought two of those saws. Both are still running great now that I am 61. I assembled my second new chainsaw (if we count the Stihl pole saw I got three years ago) since that long past previous purchase just last night. A lightweight rechargeable electric EGO for limbing and trimming. It has a plastic knob for bar clamp and another plastic thumb wheel for chain tension.
When I am 101, I bet the Super XL/AO saws are still going, but the pole saw and the EGO? I very much doubt that.
prs
/ Tightening bar nuts #11
Reminds me of the tire places tightning the damned lug nuts to **** and back!!!Way to tight!!!
I have had that happen, but not anymore. I demand to see installation and ask for them to be torqued. I had three lug nuts cross threaded by young kid using impact wrench with nut placed in socket! Owner then wanted me to pay for replacement!
Owner wanted you still Pay!!! BS on that one!
Yeah-- I WAS a long time customer and he said they were like that when it came in, even though he knew I was a certified mechanic.
Last time I ever bought tires from him.
/ Tightening bar nuts #15
Never too old to screw up. I just over tightened the bar nuts recently. I couldn't figure out why the bar was smoking........DAh-h-h-!.
Then I checked things out and discovered the bar nuts too tight. I couldn't believe that I had done that. Thanks for the thread to confirm my stupidity.
Cheers,
Mike
/ Tightening bar nuts #16
Yup, I know what you mean Giles. I had a mechanic that I thought was trustworthy, I went to him with all my car repairs for about 5yrs. He screwed me on two repairs on a Ford Windstar and that was it. I knew right down to the dime of how much those repairs including cost we be, he lied right to my face about it. And here I am picky as **** about who works on my vehicles to begin with...I guess it's back to doing my own repairs in my driveway..LOL.
I do all my repair. As long as I am able to lie down, get up and down, I will do my own work.
But, people like us can't do some jobs that require expensive equipment and sometimes it just makes more sense to have it done.
If shop won't let me see the work being done, and I know their reasons, and I go elsewhere.
/ Tightening bar nuts #18
Speaking of bar nuts...I just picked up used Husqv 372xp from yard sale...Score! The home owner had no business owning a saw of that caliber not to mention the house was in a suburb neighborhood, bar nuts were so tight it was like they were put on with an air wrench and then loctited, lol. Put a new plug, cleaned the carbs, tuned it, now I have 372XP in the arsenal...Time to wrip it!!!
/ Tightening bar nuts #19
Just came back from buying the 2.50 Stihl bar nut. Put on a new sharp chain, and forgot to tighten one nut after adjusting the screw. Chain was still cutting good - just lost the back nut in the woods.
/ Tightening bar nuts #20
That is quite the score, if you got a good price. The new units list for more than $900, and you can even get
heated grips and intake.
I have just converted the circular saw variant of the 372XP to chainsaw, and it is awesome.
2022 EZ-GO ELITE...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
24in. Terex Excavator Bucket with Teeth (A64194)
24in. Terex...
