Tight rockshaft on 4400
   / Tight rockshaft on 4400 #1
cerescobra
My friend is experiencing difficulty in moving the rockshaft to raise/lower the 3 point hitch. He also feels it is not moving it's full travel. Any experience with this problem? We have removed the housing around the hydraulic valve, but haven't pinpointed a problem yet. It is just takes alot of force to operate the rockshaft.
Thanks,
Chuck
   / Tight rockshaft on 4400 #2
There are several pivot points that need lubrication, as well as friction washers (#10) that can be adjusted.
Thanks Kenny. We've taken all the washers and levers off the shaft and it is still tight, suggesting it's something in the linkage or the hydraulic valve we're guessing.
Chuck
Problem solved. After removing the control valve cover, we found the rockshaft was very tight in it's bushing. So applied several hits of WD40, rotated it repeatedly, and it now works like new. Not sure why it bound up, but it was an easy fix.
Thanks for your support!
Chuck
Harvest International H1072 Transport Auger (LIKE NEW) (A50775)
Harvest...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
2010 Chevrolet Traverse (A55758)
2010 Chevrolet...
New JMR 40" Skidloader Grapple (A50775)
New JMR 40"...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2022 Chevrolet Tahoe FL SUV (A55758)
2022 Chevrolet...
