TIG welder options
/ TIG welder options #1
Locoweed
West Tx.
Kubota B2620
I am interested in learning TIG welding. I am just a hobbyist. I have a Lincoln 210MP that I could buy all the stuff I need to make it TIG capable. The price to buy their stuff is a bit over the top IMHO. Other folks make kits to convert the 210 to TIG capable, but I知 not sure of the quality of these other kit brands.
The other option is a Chinese welder. I am not overly interested in supporting China at the moment, but the cost benefit analysis may take me there anyway. If I had any plans to get a lot of use from the TIG it would be different. This will mainly be a adventure in learning & a small amount of use doing thin stuff after that.
If anyone else has been down this road & would like to share their experience, it would be appreciated.
/ TIG welder options #2
All you should need is a Tig torch. You ca get one to fit the MP for $60 online.
/ TIG welder options #3
IF you have a DC machine then all you need is a bottle of argon, a flowmeter, a short length of hose and a TIG torch and some TIG wire of the type to match the material your want to weld. ER70s-6 works for mild steel. A high frequency attachment is nice but a scratch start TIG is all I ever had when I welded pressure piping.
I do love my new Everlast 206 SI Plasma/TIG/ Stick machine with high frequency start . It came with everything but the Argon bottle and Tungsten.
/ TIG welder options #4
A foot pedal is also handy. Makes life easier, IMO. Hi Freq is nice, but maybe it can do lift arc also? I don't know this machine to say either way.
/ TIG welder options #5
/ TIG welder options #6
This is an interesting thread for me. At some point I will get a TIG set up. I want to do more thin steel and learn aluminum. Look forward to the advice here.
/ TIG welder options #7
Before all of the little DC tig/stick machines started to filter into the market, We converted the Lincoln SP100 Mig machines to do scratch start Tig. It worked ok but slightly over 1/8" was the top end and the duty cycle was fairly low. The 115v machines worked best for this because they would turn down much lower than the 230v units. So any 115v Mig machine can be converted to scratch Tig for the cost of a torch and a 105Z57 power block. All for under $75. Still I would recommend saving for a 200 AC/DC full featured machine.
/ TIG welder options #8
The Lincoln 210mp is a mexican made unit with a high content of chinese components. But the NOVA kit for the unit has a higher rated pedal than the SCC built kit, which is the OEM lincoln one. The OEM lincoln one is rated for 1 million cycles and uses a mexican built potentiometer. The Nova kit uses a Japanese built potentiometer that is rated for 2 million cycles but the pedal itself and kit is built in China. This kit has few issues and is very popular in lieu of the Lincoln sold one.
2011 John Deere 1770NT Planter (A63109)
2011 John Deere...
FIFTH WHEEL ATTACHMENT PLATE (A63569)
FIFTH WHEEL...
2022 John Deere Z930R Zero Turn (A63116)
2022 John Deere...
2023 Kubota SVL97-2 Compact Track Loader (A63118)
2023 Kubota...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
240 Massey Ferguson Tractor (A61165)
240 Massey...
