Tig weld problem
/ Tig weld problem #1
BeezFun
Elite Member
IL
Kubota B2710
Not sure if this is contamination or what, but I've been welding this frame together with no problem on all the other joints. All of a sudden this one joint causes sparkling and popping, it contaminates the tungsten even though the tungsten doesn't touch. In the photo you can see it leaves a brown residue and a very pock marked looking attempt at a weld. What's causing this? This is the same material I used on the whole frame, it's 3/4" square steel tubing with .065 wall, same welder, same filler, same human doing the welding. Could this be oil or something that's inside this one piece of material? 20160519_193320.jpg
/ Tig weld problem #2
It could very well be some oil.
Is it possible a breeze may have blown your gas coverage away?
/ Tig weld problem #3
That looks about like what I get when I forget to turn the gas on. Can you hear the gas flow? Solenoid stuck? out of gas?
/ Tig weld problem
I'm in the garage, no breezes. Plus it's just this joint. I'm thinking oil, but wow, I've never had anything like this.
/ Tig weld problem
Gas is working, I welded a few other pieces and it worked fine, but you're right it's kind of similar. There's something about just this joint, so either the metal itself has some kind of contamination in it (not likely), or there was some oil inside that I didn't get out.
/ Tig weld problem #6
I've never had it happen when Tig welding steel. But Tig welding aluminum, when the argon bottle gets low, it will play havoc on aluminum welds.
/ Tig weld problem #7
SA
Did the flow meter/regulator still show a steady 15-20cfh or did it vary as it got low in the bottle when this happened?
/ Tig weld problem #8
SA
Yes the flow meter showed 20-cfh. The bottle still had some argon in it, so I didn't worry about it. Then the welds went bad. Guys on the Miller forum informed me not to let the bottle get that low when Tig welding aluminum.
/ Tig weld problem #9
Is the tubing closed on the other end? Pressure will build up and force the atmospheric air out the joint contaminating the puddle. I ran into that problem a lot when doing s/s tubing rails, same with aluminum as well. I ended up drilling holes that would be covered by the pipe before I tacked it together to prevent pressure build up....Mike
/ Tig weld problem
Problem solved, here's what I did. I drilled an 1/8" hole in the bottom of the square tube near the end that had the contamination problem. Then I stood the frame up on end so that piece is oriented vertically and injected acetone in that hole with a horse syringe. I collected the acetone that ran out the bottom through the parts of the bad joint that I hadn't welded yet. There was a lot of dark sediment that looked like grinding dust that came out, presumable there was also oil. There was still a little hissing and spitting when I rewelded that joint because there was trapped impurities in the old weld, but it came out pretty good all things considered. When I originally cut all these pieces I cleaned them in a parts washer with hot solvent, my guess is I somehow forgot to clean this piece. Won't make that mistake again. 20160520_183509.jpg20160520_173927.jpg20160520_173839.jpg
/ Tig weld problem #11
Glad you got it figured out.:cool:
Now the big question, what are you building? What little I can see, it looks very interesting! :drool:
/ Tig weld problem
It's a stand for my wife's horse to get up on and do tricks. Like how the elephants get up on a stand at the circus and stand on their rear legs. I have one made out of wood but it probably weighs 150# and I'm not getting any younger, so I made one out of steel tubing. It should weigh 60# when I'm done if my calculations are correct, that's pretty easy for 2 people to carry. I'll post a picture when I'm done, I still have a few pieces to add that support the center of the platform.
/ Tig weld problem #13
Love to see a picture of it!
I use to have horses; I could never get my horse up on a stand. :eek:
TAKEUCHI TB230 EXCAVATOR (A64279)
TAKEUCHI TB230...
2022 Case CX220E Hydraulic Excavator (A61572)
2022 Case CX220E...
HARDEE 6' BOX BLADE (A63291)
HARDEE 6' BOX...
BARRY HILL 20 GALLON ALLY WAY SPRAYER, 3PT (A63291)
BARRY HILL 20...
2014 MERCEDES 2500 CARGO VAN (A59911)
2014 MERCEDES 2500...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
