Tierod seal
/ Tierod seal #1
arkadillo
Elgin, Texas
Kubota 3010 GST
Does anyone if the rubber boot can be replaced on the tierod end on the Kubota L3010. I kinda of messed it up pushing over trees.
/ Tierod seal #2
Sure it can be replaced. I think Kubota just calls it a "dust cover". There is a special tool for separating the tie rod ends, although I know a lot of mechanics use a big hammer instead./w3tcompact/icons/laugh.gif
Bird
/ Tierod seal #4
the tool that you need is called a pickle fork. it will work much better than a hammer.
/ Tierod seal #5
Boatman, I never heard 'em called a pickle fork before, but that's the reason I didn't give a name for the tool./w3tcompact/icons/laugh.gif I've heard 'em called tuning fork, ball joint separator, tie rod spreader, pitman arm wedge, etc./w3tcompact/icons/laugh.gif
Bird
/ Tierod seal #6
I just replaced the left tie rod on my L4310. It was easy. I have a ball joint removal tool. It is 3/4" thick steel bent into a "C" shape. First remove the ball joint nut and then use the tool. One side of the C slips under the dust boot and the other side of the C has a BIG fine threaded screw that pushes on the end of the threaded part of the ball joint.
Before I got the tool I would use a large pry bar (6 to 10 ft) on the tie rod near the end I was removing. Then with a large hand mallet hit the middle of the "circle" where the conical part of the ball joint slips into. By hitting it in the middle it defroms the area very, very slightly thus allowing the ball joint to pop out. AFter 2 or 3 good solid hits it will pop out.
Never ever hit the threaded part of the ball joint where the nut goes on. It will deform the threads and you will never get the nut back on.
/ Tierod seal #7
<font color=blue>Never ever hit the threaded part of the ball joint where the nut goes on</font color=blue>
Rich, I'm still not sure I'd recommend it, but I watched mechanics in a shop that did a lot of front end work and they never used one of the tie rod separators; they just backed that castle nut to barely above the end of the threads, then hit it with a 2# hammer. I tried it once; didn't come loose, and the mechanic said, "No, no, no, you've got to HIT it." They definitely did not pull their punches with that hammer./w3tcompact/icons/laugh.gif I was afraid of breaking something with their method, but in 4 months there, I never knew of one of them to break anything.
Bird
2007 IC Corporation PB105 School Bus (A64194)
2007 IC...
2015 Scag Turf Tiger 60in Zero Turn Commercial Mower (A64553)
2015 Scag Turf...
METAL GRAVITY WAGON (A64278)
METAL GRAVITY...
2008 Ford E-450 Super Duty Ambulance (A64556)
2008 Ford E-450...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
1996 Ford F-350 Pickup Truck (A64194)
1996 Ford F-350...
