Comparison Tier IV Questions For Messicks
   / Tier IV Questions For Messicks #31
My empirical observation is that operators are trying to operate these machines at just above low idle RPM as it has always been done. Lugging these engines around causes excessive soot and problems. They equate high RPM operation as causing excess wear and fuel consumption.
These new engines are designed to be operated at PTO speed (or very near).
Just my humble opinion.
That's one thing I've heard. If true, one of the key diesel advantages has been lost.
Rgds, D.
   / Tier IV Questions For Messicks #32
So with the Tier DPF, you must run the engine at a much higher RPM and burn more fuel to improve the air quality? It doesn't make sense. Of course not much that the government mandates makes sense. :confused3:
The biggest waste would be running the tractor at or near PTO speed while operating the backhoe. I have never required or wanted the tractor engine to run at that high of RPM while using a backhoe on any tractor. :rolleyes:
   / Tier IV Questions For Messicks #33
I only use that kind of engine speed when I'm using the PTO or the backhoe. Otherwise, chug, chug, chug. For 135 hours in a year, no issues. No DPF, either!
   / Tier IV Questions For Messicks #34
Cincy,
Not to distract, but is it you who has a long backhoe, similar to my own? How is it working out, if it was you of course, and mine is much smoother at lower rpm's, w/ no compromise in efficiency/production.
   / Tier IV Questions For Messicks #35
They are exempt. There are also a whole bunch of Tier IV Interim machines that automatically meet Tier IV Final.
The biggest problem I see here on TBN is that there is a perception that the new Tier IV Final machines are special and everything before that was Tier III. But Tier III only applied to higher horsepower machines and only for a limited number of years. Most other compact tractors have been Tier IV Interim for many years. This chart has been helpful in separating things out:
418264d1427335136-last-l-grand-l-series-tier-chart-png
For some reason, the horsepower cutoff is hazy among manufacturers, and it seems like more than the conversion/rounding from 19 kW to 25.479 HP. There are plenty of machines that are slightly over 19kW but meet the EPA cutoff for Tier IV Final without any emissions controls. It's a mystery unless there is some RPM limit that holds them back. For example, the Kubota L2501 has the old 34HP L3400 engine and it's simply RPM-governed to stay below Tier IV limits. How that is legal is something between Kubota and the EPA I guess. But it's a clever way for Kubota to sell a powerful torquey tractor that doesn't need any emissions controls.
Nice chart. I am one of those that thought all the Tier 4 problems and regs just recently started. That may be because until very recently I had zero interest in acquiring any new equipment especially a tractor.
All the hand wringing, complaining, and (i need a better word) whining is new to me.
   / Tier IV Questions For Messicks #37
Tier IV doesn't say how emissions requirements/levels are to be met. Some manufacturers, Mahindra being one I know of (or did at the time I was shopping for a larger tractor), boasted of meeting Tier IV w/o a DPF. A DPF is just a "strategy"/system used to meet Tier IV requirements.
Smaller engines, from how I'm gathering/reading, seem to produce less soot and that this can be dealt with without DPFs. This is my understanding. I have not delved into the true FACTS because I was not shopping for a smaller tractor.
Regardless, if an engine is to meet Tier IV it is tested and verified to meet Tier IV emissions. How it's done differs (and for some, as VW did, it is "met" using "interesting" means).
VW was in trouble for NOX gases, that it. Don’t know why they did it some of their cars had DEF fluid, all it would do is use a little more than it did. It makes no sense why they did this. But after this they did emission test on diesels in Europe and VW had the cleanest ones. Who would of thought. All brands in Europe cheat, but it was allowed under the law. I had a 2013 Passat TDI it was a very nice car. It was large, had a big trunk and got 50 MPG on the highway. I would still own it but VW offered me too much money for it for the buyback. I had it 4 years put 53,000 miles on it and lost $4,000 from my purchase price and I bought it brand new. If you know any other vehicles you can do that with let me know.
   / Tier IV Questions For Messicks #39
All you need to know about servicing your Kubota DPF but we’re afraid to ask......
http://www.kubotaengine.com/assets/...ter Handling Manual_Sept_2013_9Y111-07332.pdf
When I was looking for a Mini-Ex, I went to the Kubota dealer to try one out. It was a cold January day and right after starting it up it went into regeneration mode. Forty five minutes later I left because it just kept going. They had to tow it inside and heat up the machine to get it to finish. Not a good showing and not sure how this could be attributed to “90% of problems being operator error”.
I ended up with a Bobcat that doesn’t have a DPF. I don’t have to run it at high rpm which makes for a much smoother machine IMHO.
   / Tier IV Questions For Messicks #40
Cincy,
Nope, my says "Mahindra", but is built in Korea.
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
2006 Mac 35ft Tri-Axle Dump Trailer (A55852)
2006 Mac 35ft...
PALADIN HTM-7201-A01-425-A4 HYD THUMB (A57192)
PALADIN...
2017 Ford F150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F150 XLT...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2023 JOHN DEERE 325G SKID STEER (A52707)
2023 JOHN DEERE...
