Wormwood
Bronze Member
- Joined
- Apr 12, 2011
- Messages
- 60
- Location
- Little Rock, Arkansas
- Tractor
- Kubota M5-111 SVL97-2 KX080-4s2
This is related to all newer tractor that meet tier III or Tier IV emissions. I can accept the new emissions and try to find warm fuzzy feeling I'm doing my part for the environment, however, for the life of me I can not understand why they have to direct the exhaust at the ground? A tractor in regeneration operating the backhoe at will surely set fire to anything that's in front of the exhaust!
So my question is, is it possible to convert the exhaust direction upward above the hood? Would you run into back pressure issues, loss of power, ecu thinking the dpf filter is clogged or even confusing the ecu into injecting too much def fluid? This assumes you have an available route to safely plumb the exhaust upward, I'm just trying to figure out if there's gonna be more issues than at first glance...
Wormwood
Wormwood
