Tier III & IV vertical exhaust conversion
   / Tier III & IV vertical exhaust conversion #11
How often do these need to be cleaned or replaced? What companies offer tractors with them?
Not very often. I know on my VW Passat they want it checked at 120,000 miles. A lot of VW TDI's are going well past the 120,000 miles. Tractors should go about 4,000 hours or so. Most tractor manufacturers use them. I think Mahindra right now is the only one that does not use it. They use a Diesel Oxidation Catalyst (DOC). Massey uses DOC on a lot, but I think there smaller ones still use DPF. Kubota I think is starting to switch to DOC. Branson offers some with DOC.
Mahindra is having a EGR problem with a lot of tractors right now. Both systems have positives and negatives.
   / Tier III & IV vertical exhaust conversion #13
Mahindra and New Holland in certain models utilize a catalytic converter which do not require a Regen or DPF...
I'd like to know more about that. How do they trap the soot?
   / Tier III & IV vertical exhaust conversion #14
It does not trap it. A DOC works like a catalytic converter for gas engines. It heats up and breaks down the soot into smaller particles.
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
JCB 532 7,000LB Rough Terrain Telehandler (A56857)
JCB 532 7,000LB...
1626 (A58375)
1626 (A58375)
2019 SPM 2500HP QUINTUPLEX FRAC PUMP (A58214)
2019 SPM 2500HP...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
INSPECTION (A57453)
INSPECTION (A57453)
