Tier 4 emmisions, best options out there?
   / Tier 4 emmisions, best options out there? #1
dntfxr
Platinum Member
north Louisiana
Ford, LS
Hi folks, I I've just started researching new tractors and found some info on the new LS xu5055 and xu5065 models, apparently the new Shibuara engines achieve emission standards without the use of a dpf, through efficiency, common rail, and an egr. This seems more desirable than using a dpf from my experience with trucks. I was under the impression that all tier 4 tractor motors used a dpf. Are there any other new models out there that work similar to this? Sorry if this has been covered but I haven't found much info about this.
   / Tier 4 emmisions, best options out there? #2
There was a thread here recently that talked about Kubota having a series of engines that didn't have a DPF. I sure hope the industry continues in that direction, DPF's have been a thorn in my side on pickups...
   / Tier 4 emmisions, best options out there? #3
Mahindra, as far as I know, has no DPF models. Perhaps some of the rebadged Mahindra models may. From my understanding DPF has just been a "quick fix" for some manufacturers while research was being performed, nobody likes DPF...
   / Tier 4 emmisions, best options out there? #4
The best option is to find a cream puff tier 3 and buy it.
   / Tier 4 emmisions, best options out there? #5
Just bought a 2014 NH Workmaster 55. The book lists it as a tier 3 engine.
   / Tier 4 emmisions, best options out there? #6
If there was a tier4 or interim tier4 that didn't have all the cost raising DPF stuff on it, on the lot side by side with an older "creampuff" tier3, I don't think I'd go with the older unit. The tier4 stuff is much more efficient. Diesels that use DPF to achieve the higher standards have long claimed the increased efficiency would pay for the increased system cost over time. I'd think that diesels that don't need DPF and it's associated costs to achieve the higher standards would be the most cost effective overall...
   / Tier 4 emmisions, best options out there? #7
If my choice was a egr system vs a def system. I would go with Def. At least in the large diesels the egr systems are very high maintenance. Both are much more maintenance than the tier3.
Thanks folks, I may look for some tier 3 machines. I've been by 2 NH dealers and neither stocked any of the large frame Workmaster models, but they look good in videos. And I've found some 5e Deere models and they look nice. I like the M7040 Kubotas too if they're still available.
   / Tier 4 emmisions, best options out there? #9
Mahindra Tier 3
If any of you are still wanting the tier 3 models, I have about 100 models in stock. We ordered heavy just so we could pass on the savings of these models. Contact Jimmy at 910-465-3070
   / Tier 4 emmisions, best options out there? #10
What kind of maintenance for the EGR?? EGR is exaust gas recirculation and wasn't aware of any maintenance needed for it. DEF is diesel exaust fluid. Did you aim to say a diesel particle muffler?
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
CATERPILLAR 302.7CR EXCAVATOR (A52705)
CATERPILLAR...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
2012 VOLKSWAGEN Passat (A55758)
2012 VOLKSWAGEN...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
