Tie/stap down procedures?
   / Tie/stap down procedures? #1
Hotelsierra
California
Ford 3000
I am curious what you guys are using to secure your tractors to trailers? Chains I would think, but I am new to trailering tractors, so I dont have a clue.
What type of chains and binders? Where are the secure points?
Any info securing a load is appreciated.
Thanks!
   / Tie/stap down procedures? #2
Thanks!
The one thing I will offer is check with your State (or neighbouring ones, if you will haul that far) concerning certifications on the chains/straps/binders.
The regulations changed here (Ontario, Canada) not long back, if you don't have the right tags on the chains.... then MTO considers them invalid. Partly this was done to fight the flood of knock-off junk coming in from Asia.
Post here if you have a loader (FEL), type of trailer, and what rear attachments you will/want to haul and I'm sure the seasoned tractor-haulers will have plenty of suggestions.
Rgds, D.
   / Tie/stap down procedures? #3
I use 4 10' long 5/16 G70 chains. One on each corner of the tractor with boomers. For the FEL and 3 point implement I use a 2" strap.
Chris
   / Tie/stap down procedures? #4
General rule seems to be chains for the vehicles and straps for the attachments.
   / Tie/stap down procedures? #5
Great topic! I just purchased my first trailer to move my Kubota BX25 & attachments and could use help on what straps/chains I should use and how to attach them! Any suggestions would be appreciated!
   / Tie/stap down procedures? #6
Here is how I have been securing mine, g70 5/16 chain, and ratchet binders. I bought 2 20' chains at Lowes, had them cut in half. I also have 2 other 20 footers from Lowes, in case I need longer ones. two on the front over the bucket, since the tractor is so small, and one on the backhoe. Not shown in the pictures is a 2" strap over the backhoe bucket
   / Tie/stap down procedures? #8
View attachment 328685View attachment 328686View attachment 328687
It doesn't look like this tiedown configuration meets CFR393.130 Rules for securing heavy vehicles, equipment and machinery:
"(c) Securement of heavy vehicles, equipment
or machinery with crawler tracks or
wheels. (1) In addition to the requirements
of paragraph (b) of this section,
heavy equipment or machinery with
crawler tracks or wheels must be restrained
against movement in the lateral,
forward, rearward, and vertical direction
using a minimum of four
tiedowns.
From here: Maintenance
   / Tie/stap down procedures? #9
I do a 4 point ( 4 chains & binders) and tie my chains to the frame of the tractor. I don't worry too much about the equipment attached as I don't go very far or fast.....note in his pics how kernal hooks the chain hooks on the trailer.
   / Tie/stap down procedures? #10
Whatever you do, dont run a strap (yes, straps work is heavy enough) through any part of the machine as it will get cut. If you use straps, they should only go from trailer to chain. The exception would be axle straps and straps over the top to control 'bounce'.
91013 (A48082)
91013 (A48082)
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51691)
2013 International...
2012 Caterpillar 259B Compact Track Loader Skid Steer (A51691)
2012 Caterpillar...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
