Tie Rod End Internal Adjustment ??
   / Tie Rod End Internal Adjustment ?? #1
Arizona
2004 Workhorse 2840
This tie rod end pic that I stole from Aliexpress, shows cotter pins with several insertion positions. Does this imply that the tie rod end has end play adjustment built in? Mine sure are sloppy.
   / Tie Rod End Internal Adjustment ?? #2
   / Tie Rod End Internal Adjustment ?? #4
They used to offer rebuild kits. Some had a inner and outer cup you could replace.
Recently, the tie rod ends at each tire, were at their loosest settings. The slot across the top of the tie rod end would not hold any tool I have, except for a flat stamped steel wrench (spanner) from either a die grinder or an angle grinder. The fingers of these wrenches fit perfectly into the ends of the slot atop the tie rod end. Had to turn it clockwise from above with an adjustable wrench. Each 1/2 turn I pulled up on the tie rod end to check for slop. After around 2-3 turns, there was no slop left. The steering was greatly improved.
Mike
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
