Thumb grapple install need help
/ Thumb grapple install need help
Looks nice. You made your own bulkhead. I'm going to try a Cushing clamp mounted on unistrut. My intentions are to never take the loader off. If it has to come off it will be a mechanic splitting the tractor. I need to.get a hose sleeve to protect them.
/ Thumb grapple install need help #22
Yes, I TIG welded up two pieces of the Kubota sheet metal on the edges to make the bulkhead the thickness that it is. and I also welded up the copper crush washers to tighten up everything when I miscalculated the thickness of the bulkhead. :eek:
You can read about it here if you want.
http://www.tractorbynet.com/forums/...-quick-connects-loader-torque.html?highlight=
Here the cushion clamps. I got them on today
Sent from my iPhone using TractorByNet
