Thumb ... GEEZ IT"S HANDY !!!
   / Thumb ... GEEZ IT"S HANDY !!! #32
Re: Thumb ... GEEZ IT\"S HANDY !!!
your mower is going to love you!!!!
surfran: Thanks!
Scozz: Yes, it's been mighty grouchy lately /forums/images/graemlins/wink.gif
   / Thumb ... GEEZ IT"S HANDY !!! #34
You guys keep making my list of projects longer and longer... /forums/images/graemlins/blush.gif /forums/images/graemlins/cool.gif
   / Thumb ... GEEZ IT"S HANDY !!! #35
I am curious If I can expect the same awesome rock lifting results with a JD 448 back hoe? I honestly had no idea that a compact utility tractor could come close to lifting those kinds of loads! I see industrial TLB pick up the same size rocks, but the tractors are 3 times the size. Am I under estimating the cabibility of compact utility tractors? I am seriously thinking about getting a 4020 series with the 400X loader and 448 backhoe setup. I'm looking for those awesome rock picking characteristics! I guess I have lil faith in most manufacturers claims. JD says 800+ lbs of lift at pins, at full extension. Do you think that's accurate? so figure 800 - 300 for bucket and claw = 500 lb lift ability? Any ideas would be greatly appreaciated! Thanks ! Brian
You may have noticed that a lot of the rock and stump picking operations relayed on this forum are using a Kubota BX22/23. That's pretty close to the smallest TLB out there. I would have to think a JD 40xx would have more capacity, but I don't really know. My manual shows a lifting force of ~500# a bit before max height but I don't know if that's including the bucket weight or not. I do know that when my boom runs out of power or height, I can use the dipperstick to get more height.
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2016 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2016 Kawasaki Mule...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56435)
2012 MACK Tender...
2009 Dodge Ram 3500 Flatbed Truck with Liftgate (A55973)
2009 Dodge Ram...
48X96 JMR WORK BASKET (A56857)
48X96 JMR WORK...
