Thumb for mini hoe
/ Thumb for mini hoe #1
bbabineau
Atascadero, California
Attached are pictures of a thumb that I had made for my hoe. I did not want one welded to the hoe so I designed one that bolts on and folds back out of the way without removing. So far tests have been successful but I may want to later make a longer thumb but that should be easy since it is simply a two inch tube with notches cut. It is pinned on so is easy to remove.
/ Thumb for mini hoe #2
great implementation. I like the way it folds up when you are not using it.
/ Thumb for mini hoe #3
Is this something that others can buy? Any details you can share? Thanks
If there is enough interest and if my testing comes up with satisfactory performance, I will ask the fabricator who made it if he is interested in making more and what the price would be.
/ Thumb for mini hoe #5
I would like one if the price is reasonable.
/ Thumb for mini hoe #6
GREAT LOOKING THUMB. LIKE THE IDEA OF BEING ABLE TO MOVE OR REMOVE IT IF NEED BE.
/ Thumb for mini hoe #7
How's the testing coming? I have an upcoming project where a thumb would be very helpful-- is the fabricator interested in making more?
/ Thumb for mini hoe #9
Add me to list. I was going to weld one up, but I really like that this one folds and is removeable. I would buy one also if the price was fair.
Selkirk
/ Thumb for mini hoe #10
My goodness those are some fine thumb pictures you posted there! Large too! :eek:
/ Thumb for mini hoe #11
"My goodness those are some fine thumb pictures you posted there! Large too!"
Well, you know what they say about large thumbs.............
large gloves!! LOL!
I told the fabricator that the target price was $225 which would make it competitive with those on ebay that need to be modified and welded to the mini hoe. After making mine he said he would not make another for the $225 but it would be closer to $300 plus shipping.
As for my testing, I would probably make one or two changes. I think I would ask for the first set of teeth on the arm to be left with the full tube rather than cut out into the teeth. This would add some strength to the very end of the thumb. I would also want the thumb an inch or two longer.
If anyone is interested, I will again approach him to see if he has the time and desire to make a few more!
Bob
/ Thumb for mini hoe #13
bbabineau, I am building a thumb and as much as possible I am building it like yours. Is there anything that you would change? Is it holding up well?
Thanks for any comments on this.
/ Thumb for mini hoe #14
Bob,
If you can, I'd suggest that you make the thumb slightly curved forward. This will allow it to firmly grip rounder objects (trees, rocks, etc.) without requiring as much "curl pressure" to keep it clamped tightly against the thumb...
Without the curve, it is only the pressure against the point of the teeth that is holding the object... Most aftermarket thumbs are curved. Note mine, before we shortened it...
ImageShow.aspx
http://mypowertrac.com/DesktopModul...ImageID=23&alias=mypowertrac.com&ImageSize=10
/ Thumb for mini hoe #15
KentT said:
Bob,
http://mypowertrac.com/DesktopModules/Polle.PiGa/ImageShow.aspx?ModuleID=384&GalleryID=6&ImageID=23&alias=mypowertrac.com&ImageSize=10
Thanks, I think I can heat it up with the weed burner and put some curve in it. Some other questions:
1. What size bolts did you use between the top plate and the bottom plate (long bolts)?
2. What size bolt did you use to pivot the thumb on?
3. Are those 5/8 inch receiver pins?
4. I have assumed that the thumb is made of two inch square tube. Am I correct?
/ Thumb for mini hoe #16
Unless I'm mistaken, my thumb is made of 3.5" C-channel, and the mounting plates that are welded to the boom are 4" C-channel. (The plates are slightly wider than the PT's boom.) The thumb attaches to the mounting plates on the boom with standard hitch pins and clips -- I'm guessing 4.5" ones. Consequently, I can take the thumb off, leaving only the mounting plates, by pulling the two hitch pins.
The minihoe is in TN and I can't go verify...
/ Thumb for mini hoe #17
Thanks KentT. I put the curve in it kinda. I cut some slots, heated it up and it mostly bent at one slot. I will now weld the slots back in. I think I will use all hitch pins for easy removal per your suggestions. What size bolts did you use between the top and bottom plates?
bbabineau, can you answer the question that I put below? It's good to get several opinion and I am pretty much copying your design.
/ Thumb for mini hoe #18
No bolts were used, The plates are welded on, and the thumb and its brace are attached with pins...
/ Thumb for mini hoe #19
I am attaching a few parts pictures. KentT, do you think I put enough curve in the thumb. It's not too late to bend it a little more?
I used the weed burner to heat the thumb, but it seem to bend all along one of the cuts. I would like comments on additional bending and where if anybody has suggestions. I think I should straighten the one that is bent too much and bend the other two slots.
/ Thumb for mini hoe #20
Bob,
I think that amount of angle will work fine. Now, just weld up the cuts necessary to bend it... :)
It's looking good. How long is it? While you're "playing with measurements" see if you can make it adjustable so that at one position it will go completely inside the bucket, yet in another position it will mate up with the bucket teeth...
2008 INTERNATIONAL DURASTAR 4400 CAB AND CHASSIS (INOPERABLE) (A60736)
2008 INTERNATIONAL...
John Deere 6110M (A60462)
John Deere 6110M...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2024 JOHN DEERE 325G SKID STEER (A62129)
2024 JOHN DEERE...
2017 TROXELL 130 BBL STEEL VACUUM TRAILER (A60736)
2017 TROXELL 130...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
