Thumb for JD 110 tlb
   / Thumb for JD 110 tlb #1
KRH
E\'ville, NY
JD 5225 MFWD w Power Reverser; 2010 JD 110 tlb; 2007 JD 4520
Hi Guys: Read all the previous threads about pin on hydraulic thumbs. Tried to e-mail Northsaw but it got bounced back. Who makes the one for DEERE? Any others you can recommend?
Thanks for your assistance.
KRH
Thanks CurlyDave! Does it get in your way when not in use?
KRH
   / Thumb for JD 110 tlb #4
I have never had it interfere with any operation.
If I don't use it for several weeks, the hydraulic cylinder will leak down a bit, and I have to retract it before starting to dig, but this is normal, and happens to all hydraulic cylinders. I do not have to leave the seat, and it takes about 3 seconds, 2 of which are figuring out which way is up on the treadle and which way is down.
Thanks !!! If you have some time could you send me a couple pics of the thumb on your 110 in both the open and closed positions. Send to my pm. Really appreciate it.
KRH
   / Thumb for JD 110 tlb #6
KRH
I make a great 110 TLB thumb. Pics on the website. Email should work.
   / Thumb for JD 110 tlb #7
What kind of money are we talking about for a 110 without rear aux hydraulics?
   / Thumb for JD 110 tlb #8
I depends on the options. I make heavy duty cushioned cylinders and thumbs which cost a little more but are construction quality, or there are less expensive alternatives. I don't offer hydraulic kits if you don't have aux hydraulics but I have installed them on my own excavator.
   / Thumb for JD 110 tlb #9
Only have front aux... out of luck again...
You can add the 7th auxillary valve on your backhoe for about $300 plus the cost of the hoses. Go to jdparts.com
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2012 International Semi Truck (A50323)
2012 International...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
5K BLOWOUT PREVENTER (A50854)
5K BLOWOUT...
