Throttle vibrating back to idle
/ Throttle vibrating back to idle #1
AFChief
Hey gang! My Bx2360 throttle vibs back to idle while I'm mowing with the 60 inch MMM. I'm still under 50 hours so I'm mowing at about 2500rpm. Anyone else have this issue?:confused:
/ Throttle vibrating back to idle #3
Had the exact same thing happen to my BX2360 at about 10 hours.I got it fixed under warranty but it was a simple matter of tightening the two nuts on the end of the throttle shaft.
Thanks guys. I will check that out.
/ Throttle vibrating back to idle #5
A little drop of loctite does the trick.. I had the same thing happen to me.
/ Throttle vibrating back to idle #6
hope you referring to the cable clamp.:thumbsup:
I concur, just need to tighten down the cable clamp.
/ Throttle vibrating back to idle #7
:thumbsup:Just happened to my BX2660 at 200 hrs....but thanks to you all, I already know what to do.
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
43018CFL (A59228)
43018CFL (A59228)
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
429835 (A61166)
429835 (A61166)
2015 Caterpillar 304E (A64126)
2015 Caterpillar...
