Throttle vibrating back to idle
/ Throttle vibrating back to idle #1
AFChief
Member
Hey gang! My Bx2360 throttle vibs back to idle while I'm mowing with the 60 inch MMM. I'm still under 50 hours so I'm mowing at about 2500rpm. Anyone else have this issue?:confused:
/ Throttle vibrating back to idle #3
Had the exact same thing happen to my BX2360 at about 10 hours.I got it fixed under warranty but it was a simple matter of tightening the two nuts on the end of the throttle shaft.
Thanks guys. I will check that out.
/ Throttle vibrating back to idle #5
A little drop of loctite does the trick.. I had the same thing happen to me.
/ Throttle vibrating back to idle #6
hope you referring to the cable clamp.:thumbsup:
I concur, just need to tighten down the cable clamp.
/ Throttle vibrating back to idle #7
:thumbsup:Just happened to my BX2660 at 200 hrs....but thanks to you all, I already know what to do.
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
S/A Towable Solar Speed Radar Trailer (A64194)
S/A Towable Solar...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
1998 VOLVO AUTOCAR WATER WELL DRILL RIG (A65643)
1998 VOLVO AUTOCAR...
