Throttle Slipping
/ Throttle Slipping #1
JohnInAla
Grand Bay, AL
Yanmar YM2000
My YM2000 is running great, but the throttle lever slowly creeps back decreasing RPM. I checked the owner’s manual but could not find an adjustment. It looks like I could tighten the nut on the lever assembly to create more friction. Is this the right way to adjust?
Thanks, John
/ Throttle Slipping #2
You are correct. It has a double nut lock. You loosen the outer and tighten the inner. Then retighten the outer to keep it from loosening. I always put some lube on it before and after adjusting.
/ Throttle Slipping
Thanks kayssupply, that's what I thought.
John
/ Throttle Slipping #5
My Yanmar Ke3d had the same problem. I had to take the steering wheel off to then take the dash off to get to the mechanism. It too has two nuts and a friction washer like the others described.
Mark in PA /forums/images/graemlins/smile.gif
10x20 Barn Style Shed (A62613)
10x20 Barn Style...
Prime 283 (A64126)
Prime 283 (A64126)
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
2018 John Deere 3033R (A64126)
2018 John Deere...
New/Unused Landhonor No Till Seed Drill (A65583)
New/Unused...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
