Throttle lever problem fixed!
/ Throttle lever problem fixed! #1
DiskDoctr
Platinum Member
Western PA
Mahindra 3510
This happened some time ago, but I thought maybe it could benefit someone.
On my 2004 3510 the throttle lever was stiff for a while then stopped working all together. The foot throttle was fine and the tractor ran fine.
I pulled the steering column cover off and the lever had a small piece that looks like a bent piece of 1/4" rod (IIRC) that contacted the throttle mechanism.
This rod was a tad bent and when move to far position would actually move away from the throttle mechanism. At one point it slipped past and poof, no throttle.
I simply bent this rod toward the throttle mechanism and perpendicular (it was a bit bent) after returning it to the right position with respect to the throttle mechanism.
The throttle had seemed stiff since the beginning, almost like a sticking cable, but after bending this to the new (proper?) postion/shape, it is smooth. Must've been an assembly oversight?
Sorry, no pics. This was some time ago.
Hope this helps someone!
- JC
1952 John Deere A Tractor (A66408)
1952 John Deere A...
2023 Kubota RTV-XG850 Sidekick (A66408)
2023 Kubota...
County Line 3Pt Chisel (A66408)
County Line 3Pt...
Landhonor Quick Attach Brush Mower (A66408)
Landhonor Quick...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2006 Ford E-250 Cargo Van (A64556)
2006 Ford E-250...
