Throttle Detent on YM1610D
/ Throttle Detent on YM1610D #1
Mech
Pine, CO
3520 CAB
I have a 1610D and wondered if the throttle is supposed to have a detent when going from idle to fuel cutoff. My throttle has no change in friction at all. My parts book shows a ball/spring on the side of the throttle that I thought might act as a detent.
Thanks,
/ Throttle Detent on YM1610D #2
Thanks,
Is the ball/spring there?
I didn't see them when I took everything off to rebuild the steering box. I need to take the side cover off and see if this is even the same throttle linkage that the tractor should have and if there is a place for the spring/ball. I just wanted to know if the tractor should have a "stop" at the idle point, which it doesn't do.
thanks,
/ Throttle Detent on YM1610D #4
My 1602D doesn't, I just pull out on the fuel shutoff to stop the engine. On the throttle, mine is set up to where all the way forward is just the idle, it doesn't shut it off that way. It uses a friction washer to hold it in position, no ball and spring setup........FWIW.
My 1610D doesn't have a separate fuel shutoff. You have to push the throttle all the way forward.
/ Throttle Detent on YM1610D #6
Jagman,
What you are pulling out and you called the fuel shut off is probably the compression release which holds the exhaust valves open. It should shut off with the throttle lever. If it does not it need to be adjusted.
My 1510D had to be adjusted at the pump (rack) so that it would shut off when the throttle lever was pushed all the way forward.
Mike
Mine does have a compression release but I would certainly never shut it off with that. Mine does shut off when I push the hand throttle all the way forward but there is no "stop" at the idle point and I was wondering if there is supposed to be?
thanks,
/ Throttle Detent on YM1610D #8
Mech,
My comments were not directed to you but to jagman. My 1510D does not have a detent position for idle.
Mike
Sorry for the misunderstanding and thanks for the information. Also I looked back at some earlier posts and some Yanmar's apparently do have a fuel shutoff and a compression release.
/ Throttle Detent on YM1610D #10
There's no detent or fuel shutoff on my YM240 (YM2000) either - just push the throttle lever all the way to the end to kill it.
/ Throttle Detent on YM1610D #11
thanks,
No.
Danny
/ Throttle Detent on YM1610D #12
Mech said:
... some Yanmar's apparently do have a fuel shutoff and a compression release.
That is correct. My 2220D has both. They are identical T-handles with the compression release on the left side of the pedestal and the fuel shutoff on the right side below the throttle lever.
/ Throttle Detent on YM1610D #13
My 1602D does in fact have both a compression release and a fuel shutoff......in this photo, the T-handle on the right, down by the key fob is the fuel shutoff. The compression release can just be seen on the left, below the steering wheel, a grey L shaped lever you pull out.
/ Throttle Detent on YM1610D #14
You are right Jagman and I spoke (wrote) out of ignorance. Sorry to impugn your veracity.;) There is always something to learn. I wrote it and then realized that you were writing from the perspective of a 1602 with which I am not familiar. Sorry.
Mike
/ Throttle Detent on YM1610D #15
Mike
I was thinking the same thing Mike, except I was pretty sure Dave Knew better. Thought only the F models had a fuel shut-off.
/ Throttle Detent on YM1610D #16
Mike
Hey, no worries mate!
I'm always surprised at the variety of setups I find in one MFR's lineup, and some of it does not follow logic either. Like the 1601 and 1602 being built on different frame sizes, I did not know that for example. But, that's why we're all here, to learn from each other, and I'd be the first to admit I have learned a ton already from being here, and have more than that yet to go......
It turns out my 1610D does have a throttle idle detent, at least it does now. The hand throttle has a tube on it that takes a ball, spring, and cutter key. The ball fits into a hole when the throttle is pushed forward to the idle point. My tractor had what looks like a new hand throttle but didn't have these parts. Got the parts from Hoye and it works well.
/ Throttle Detent on YM1610D #18
thanks,
No, you can "idle" at what ever speed you want, there is no detent.
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
2017 Freightliner M2 106 TMA Attenuator Truck (A64194)
2017 Freightliner...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
2006 BOBCAT 5600 TOOLCAT UTILITY WORK MACHINE (A63276)
2006 BOBCAT 5600...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
