Throttle/Choke cables insulation
/ Throttle/Choke cables insulation
Well, I slipped the cable back in last night, got it all hooked up and wrapped some of that header tape around it(that's all I could source locally). I was more impressed that I got the throttle and choke cables back in the right places. It started right up! :ROFLMAO:
After moving snow for about 20 minutes, I was done, so I checked the wrap. It was warm. I'm thinking a metal shield between the cables and hot exhaust components would do a much better job, so I'll look into that over time.
A guy showed me a trick for reducing sharp cable tie cut ends. Instead of clipping the tag end, grab the tag end as close to the zipper block with a pair of pliers and spin it around a few times. That softens the plastic and it then breaks off leaving a very small, soft to the touch nub VS that razor sharp cut. Basically, you're twisting it off VS cutting it off.
/ Throttle/Choke cables insulation #15
That's my problem with specialized tools. If you use them all day long, it is wonderful. For rank amateurs like me, the cost/benefit ratio is a bit skewed.
I just use flush cut wire cutters, and watch how I do it, but I like @MossRoad's twisty idea.
All the best,
Peter
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
