MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,166
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
My PT425 has insulation tubing around the throttle and choke cables where it passes by the engine and exhaust. After 21 years, it disintegrated and the outer rubber shield on the cable melted away, and the cables became hard to operate. I removed the cables and got them working again, and replaced the melted rubber areas with several layers of heat shrink tubing and I'm satisfied with that part of the repair.
I now need to find a source for some insulation for the cables. I think I'd like to put two layers if possible. Anyone have any suggestions? I know several of you have insulated your fuel lines to deal with vapor lock. Which product did you use? I've found several on-line. I'd like to find something locally, but no luck so far.
