Throttle cable lubricator.
/ Throttle cable lubricator. #1
Andrewcooper
Kennewick wa
BCS 716
I read about a small tool that motorcyclists use to lube their cables. It attaches to the end of
the cable and you spray oil inside a small port. This would be great for my old bcs and mower too. Anyone tried one of these?
/ Throttle cable lubricator. #2
I haven't used one of the commercially-available ones, but I have used my home-brewed version a few times. I have a combination oil sucker/vacuum pump that I made years ago using a small electric motor, an old GM a/c compressor, and an old fire extinguisher for the collection tank. If I have a sticky cable, I slide a snug piece of rubber hose over one end of it and insert the end of my vacuum pump's suction tube. Then I stick the opposite end of the sticky cable into a cup of penetrating oil and turn the pump on to pull the penetrating oil up through the cable housing.
/ Throttle cable lubricator. #3
Andrew, I have the cable lubricator like you described. It does a good job. Sometimes both ends of the cable have to be lubricated as the rust (the usual culprit) is usually at both ends of the cable.
Bill in NC
/ Throttle cable lubricator. #4
Thats a slick idea, might have to try it with my mityvac vacuum pump.
I have a cable oiler i got from harbor freight, works pretty good. Tends to be messy and use a lot of whatever your spraying in there. Havent tried it on my grillo yet but i suspect the cable diameter might be a little big for it?
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59911)
2006 CHEVROLET...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2016 Ford Transit 250 Cargo Van (A61573)
2016 Ford Transit...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
