Throttle at low speed?
/ Throttle at low speed? #1
Keef
Pennyslvania
John Deere LA135
The JD lawn tractors have a throttle that go from low to high speed. However we are told in the manual to always keep it at high. So what is the usefullness to have a throttle control when we should always keep it high? Can you have the throttle on low when not cutting the grass and just driving it from Point A to Point B to reduce the amount of gas your burning?
/ Throttle at low speed? #3
Throttle sets your power, gears or hydro setting sets your speed. If you're doing something that needs power, run the throttle near full, especially if you're machine is hydrostatic and your using the hydraulics at the same time, ie. for loader/backhoe work. If your engine is 'bogging down', rev'er higher (up to the max of course).
-J.
Ok makes sense; but how about just driving the tractor. When your are not pulling or cutting anything?
/ Throttle at low speed? #5
If your just driving around, you don't have to have it at full throttle.
/ Throttle at low speed? #6
on the 2520 if i'm just driving around the Yard in low i'll run about 1500 RPM's if i'm in high just moving empty around the yard i run about 1800.
On the Little mowers I'll run 1/2 to 1/4 throttle when transporting it.
/ Throttle at low speed? #7
Typically you want to start the blades at low RPMs as well, saves wear and tear on the belts and can save more than that if the blades are jammed.
Now you are a smart lad, thanks for that info, I did not think about that.
/ Throttle at low speed? #9
I run 1500 to 1800 when not doing ground engaging work. If I'm plowing or digging then I crank it up to 2000 or a little more.
M.D.
/ Throttle at low speed? #10
That sounds like the way to do it but check your operator's manual. The operator's manual for my JD 997 Diesel ZTR mower calls for engaging the pto at full throttle. I don't know why but that's what JD calls for.
/ Throttle at low speed? #11
Good advice, I know my chipper says to engage at idle RPMs but I never checked for other implements - just makes sense to do so. I suppose with more dedicated mowers they probably assume that most people start at full RPM anyway so they have protections against high speed starup and starting at idle speeds could stall out the engine?
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2009 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2009 GREAT DANE...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63688)
Magnolia Trailer...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
