Three Prong Plug on JD 2305
   / Three Prong Plug on JD 2305 #11
Sure can, Your dealer can get it for you. Fairly easy to install but you will need to drain and refill the coolant.
   / Three Prong Plug on JD 2305 #12
Can the block heater be retrofitted? My 2305 was sold originally by a dealer in DE so no heater. My glow plugs seem to be working great, but I would appreciate the redundancy that a block heater would provide.
Thanks.
Frank
You, just as Labrat stated...plenty of threads on them also if you search:D
Thanks Scott!!!
   / Three Prong Plug on JD 2305 #14
I had a block heater added (by the dealer) to my 2305 with 47" front mounted snowblower, about a year after I bought the tractor new. First winter, I had the tractor in a heated garage, which is also my woodshop. Second winter, liberated the shop, stored the tractor under a leanto and used the block heater. I plug it in while I do the shoveling, usually takes me 20 -30 minutes. Tractor starts better. Also use anti-gel additive.
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A55788)
2011 Ram 1500 4x4...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
