Three Prong Plug on JD 2305
   / Three Prong Plug on JD 2305 #11
Sure can, Your dealer can get it for you. Fairly easy to install but you will need to drain and refill the coolant.
   / Three Prong Plug on JD 2305 #12
Can the block heater be retrofitted? My 2305 was sold originally by a dealer in DE so no heater. My glow plugs seem to be working great, but I would appreciate the redundancy that a block heater would provide.
Thanks.
Frank
You, just as Labrat stated...plenty of threads on them also if you search:D
Thanks Scott!!!
   / Three Prong Plug on JD 2305 #14
I had a block heater added (by the dealer) to my 2305 with 47" front mounted snowblower, about a year after I bought the tractor new. First winter, I had the tractor in a heated garage, which is also my woodshop. Second winter, liberated the shop, stored the tractor under a leanto and used the block heater. I plug it in while I do the shoveling, usually takes me 20 -30 minutes. Tractor starts better. Also use anti-gel additive.
2017 Nissan Frontier Ext. Cab Pickup Truck (A55852)
2017 Nissan...
UNUSED FUTURE XKH39 - 39" MINI HYD 4N1 BUCKET (A54757)
UNUSED FUTURE...
(2) SEATER MOUNTABLE BENCH SEAT FOR SIDE BY SIDE (A54756)
(2) SEATER...
UNUSED CREEPER SEAT (A54757)
UNUSED CREEPER...
1567 (A54756)
1567 (A54756)
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
