Three point down speed
/ Three point down speed #1
corriente
Farmall 95
I have a Farmall 95 that has the slowest down rate for the three point hitch. I have a 1000 lb snow blower attached, and from full up to full down takes about 15 or 20 seconds. Could someone tell me how to adjust the down rate.
/ Three point down speed #2
There should be a knob in the operator's station under the seat. Turn it out to make the 3pt descend faster.
/ Three point down speed #3
The knob may actually be a lever, it depends on the tractor. It is generally located centered under the seat. If tightened all the way it can prevent the three point from lowering at all. The three point is powered to raise but lowers due to gravity. You may choose the lowering speed for the implement being used.
Thanks for the info. I thought that I had exhausted all options, but knowing where and what to look for solved the problem.
213064 (A64276)
213064 (A64276)
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
UNUSED X-STAR 300 GALLON FUEL TRAILOR (A64280)
UNUSED X-STAR 300...
CATERPILLAR 305E2 CR EXCAVATOR (A64279)
CATERPILLAR 305E2...
2013 BMW 550i AWD Sedan (A61574)
2013 BMW 550i AWD...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61573)
2005 Stertil Koni...
