Tractor Sizing Thread Size
   / Thread Size #1
phatgemi
This may seem an odd question but I will not be near the tractor for a while and wish to get a head start on parts gathering.
My threads are a bit messed up on the front axle spindle. I do not have metrics dies but wish to purchase the correct die for thread cleanup. What size do I need for the spindle nut on a YM2000 2WD? I.E. M18 x 1.5 or what????
Thanks in advance for any info.
   / Thread Size #2
If you have the parts book check diagram 12, part 12 (I'm saying this just so you know there is a ready source to check all those bolt sizes on the tractor). It shows the bolt size as 14x25. So 14mm is your diameter, and I know it is referred to as "standard" metric thread...I think that is 1.5. Someone else will undoubtedly know. The couple tap/die sets we have in the shop have at least two variants, maybe three for most diameters. You can buy a set from Harbor Freight for under $50 (or at least you could a few years ago)....one of ours came from there and has held up very well.
   / Thread Size #3
The spindle nut is 20m, not sure on the pitch.
Danny
   / Thread Size #4
20M x 1.5
Danny
   / Thread Size #5
In a situation like that I would recommend a thread chasing file. The are quick, and only repair what is needed without harming existing threads. I have use them alot in different situations. With one 4 sided double ended file you have about every possibility.
Mike
SEMI AUTOMATIC QUICK CHANGER FOR MINI EXCAVATOR (A53843)
SEMI AUTOMATIC...
2001  WABASH 53FT DRY VAN TRAILER (A54607)
2001 WABASH 53FT...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
