Thread size / Flare? Bx2350 ??
/ Thread size / Flare? Bx2350 ?? #1
Musclford
Central, IL - USA
BX2350
Ok, so without getting into "every" detail of why....
I have a curtis plow I attach to the frt loader arms...which I obviously have to remove the "bucket"
It could be a clean 5 minute job, but because I have to take the hoses off of the the center cylinder and hook them to the curtis plow using quick disconnect fittings.
Every year I unscrew the "thread/Flare adapters" out of my cylinder, (cleaning up the MESSY hydraulic fluid from my hands and floor) and then thread them into the quick disconnects. I then reconnect the flare side of the hose to the "adapter" which is on the quick disonnect of which I can then plug them onto the plow...
So I want to buy another set of these "adapters" Is the pipe thread end of these fittings, standard threads? Furthermore, is the other end a special flare" or can I just go get something at the local ACE hardware?
It's time to simplify... something I wanted to do 2 years ago, and never took the time.
Thanks all..
Phil
/ Thread size / Flare? Bx2350 ?? #2
Go to a hydraulic shop they will have all the pieces you need... If you have a Tractor Supply or Atwoods around your area, they carry all the pieces also... KennyV
1996 International 3800 School Bus (A64194)
1996 International...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2018 CATERPILLAR 299D2 SKID STEER (A65053)
2018 CATERPILLAR...
2019 John Deere 314G Compact Wheel Loader Skid Steer (A64553)
2019 John Deere...
