Thread size / Flare? Bx2350 ??
   / Thread size / Flare? Bx2350 ?? #1
Musclford
Central, IL - USA
BX2350
Ok, so without getting into "every" detail of why....
I have a curtis plow I attach to the frt loader arms...which I obviously have to remove the "bucket"
It could be a clean 5 minute job, but because I have to take the hoses off of the the center cylinder and hook them to the curtis plow using quick disconnect fittings.
Every year I unscrew the "thread/Flare adapters" out of my cylinder, (cleaning up the MESSY hydraulic fluid from my hands and floor) and then thread them into the quick disconnects. I then reconnect the flare side of the hose to the "adapter" which is on the quick disonnect of which I can then plug them onto the plow...
So I want to buy another set of these "adapters" Is the pipe thread end of these fittings, standard threads? Furthermore, is the other end a special flare" or can I just go get something at the local ACE hardware?
It's time to simplify... something I wanted to do 2 years ago, and never took the time.
Thanks all..
Phil
   / Thread size / Flare? Bx2350 ?? #2
Go to a hydraulic shop they will have all the pieces you need... If you have a Tractor Supply or Atwoods around your area, they carry all the pieces also... KennyV
so they are just standard parts?
Kubota L2650D Compact Tractor w/Loader (RUNS) (A50774)
Kubota L2650D...
John Deere 915 Flex Head (A50774)
John Deere 915...
378741 (A51572)
378741 (A51572)
2001 Chevrolet Tahoe SUV (A50324)
2001 Chevrolet...
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
