thread size and pitch, JD750 steering column nut?
   / thread size and pitch, JD750 steering column nut? #1
swelltimes
John Deere 750 SCUT with 67 loader
I buggered the first couple of threads on the steering column of my JD750 tractor while removing the steering wheel.
I'm pretty sure, based on the thread-pitch gauges at the hardware store, that the nut that holds the steering wheel in place is 7/16 x 20.
Before I spend $30 on a rethreading die, I'm hoping to get confirmation that 7/16 x 20 is indeed the correct size. I can't seem to find that in print anywhere I've searched.
Can anyone confirm?
Thanks!
   / thread size and pitch, JD750 steering column nut? #2
JD parts says the nut is NLA (No Longer Available) so I can't confirm from the P/N, specs are no longer listed
If the hardware store has fine thread bolts, I would see if a 7/16-20 bolt fits the nut. If not, I would then try metric bolts. 12mm x 1.25mm pitch or 13mm x 1.25mm pitch. I am not sure if this tractor used both "inch" and Metric fasteners.
Another option instead of a die is a thread file. They are sized to the thread pitch.
Or you could just file away the first couple of bad threads.
   / thread size and pitch, JD750 steering column nut? #3
Can anyone confirm?
Thanks!
Know anyone that might have a thread repair tool? Threadmate, NES, etc.
https://www.homedepot.com/p/NES-5-3...xternal-Thread-Repair-Tool-NES06040/203544733
   / thread size and pitch, JD750 steering column nut? #4
If it's made outside US is allmost always metric.
OK, thanks for the info. I did try to file away the first couple of threads, and was getting close, but want to make sure I don't FUBAR the thing.
I'll head back to the HW store and try to confirm thread size with a bolt, as you suggested.
   / thread size and pitch, JD750 steering column nut? #6
I have salvaged the day with using a very small triangle file and patiently working around the threads till its cleaned up enough to accept nut....
Dale
   / thread size and pitch, JD750 steering column nut? #7
my old parts book says it's a 12mm, but doesn't give pitch
   / thread size and pitch, JD750 steering column nut? #8
M13 bolt does not exist as a ordinary option for metric bolts.
   / thread size and pitch, JD750 steering column nut? #10
My money is on 12x1.25mm
   / thread size and pitch, JD750 steering column nut? #11
I don't have anything useful to contribute, but as far as IDing bolt size and pitch, I finally had enough and spent the money on one of these which I had saved for a long while:
Nut & Bolt Thread Checker (Inch & Metric) https://www.amazon.com/dp/B003FJW0GK/ref=cm_sw_r_cp_apa_i_NrRTCbXMAA8CG
I liked it enough that I ended up buying the other 2 options which are all metric and all SAE, both of which include more sizes. I keep those two sets hanging in the garage and take the combo one with me for off-site work. God, did I ever hate the guessing game of buying multiple possible matches in hopes one would work and never quite getting around to returning the others. BUT... Having a bunch of extra bolts and nuts in the nut-bucket does occasionally prove useful...
   / thread size and pitch, JD750 steering column nut? #12
Thanks, I was guess what would be close to 7/16", So my first guess of 12mm might be better.
Well, I borrowed a thread repair tool from AutoZone, and none of the thread repair dies would fit on to the steering shaft. The 7/16 x 20 tap went smoothly through both the old nut and a new nut that I bought.
I fussed around with a thread repair file, and eventually got to a point where the original nut went back on to the shaft with some coaxing. I used grease on the threads (Never-seize), and it seems solid. I'd wager I'll be cursing myself down the line for not making this repair 100%, but time will tell!
In addition to getting the nut back on, I finished up changing fluids and filters. They were WAY overdue, which I expected after discovering the cable to the tach was broken and not reading RPM or hours after I bought the tractor....
   / thread size and pitch, JD750 steering column nut? #14
Did you try anything metric? What size nut did you buy?
   / thread size and pitch, JD750 steering column nut? #15
Cut a quarter circle section out of a nut and use it as a thread pitch gauge. Just a thought, never done it.
Glad you got it fixed.
2005 CATERPILLAR 345CL EXCAVATOR (A60429)
2005 CATERPILLAR...
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2005 CHEVROLET 3500 HD CREW CAB FLATBED TRUCK (A60430)
2005 CHEVROLET...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
