Thread locker on fuel tank?
   / Thread locker on fuel tank? #11
Blue loctite is for threaded FASTENERS, not pipe joints. I'm sure Loctite has a product that is meant for sealing pipe joints containing gasoline.
If you look at the product data sheets under product specs is shows on the Loctite page it will tell you that 242 has 95% adhesion strength after 1000 hours for unleaded gasView attachment 580243
That sounds OK until you look at it the other way: It looses 5% of it's adhesion strength after only 1.5 months of exposure to unleaded gas.
   / Thread locker on fuel tank? #14
I was a pipefitter in a factory and if I want joints to leak, i would use something other than Loctite 242. Don't get me wrong, I used Teflon paste and sometimes tape, but a majority of the time I tried to use 242 because I didn't want to redo joints. I worked on HP grease, paint, air, water and almost anything else.
2018 Ford Transit 350HD Handicapped Van (A53422)
2018 Ford Transit...
2008 Ford F-450 Service Truck (A55788)
2008 Ford F-450...
2011 Ford E-350 Passenger Van (A55788)
2011 Ford E-350...
LOT LOCATIONS (A54313)
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
