Thoughts on a pellet stove for a large shop
   / Thoughts on a pellet stove for a large shop #41
If my calculations are correct it would take about 175 gallons of propane to equal a ton of pellets. That would make for a little bit of savings. Natural gas on the other hand is a lot cheaper than propane. At the national average price of $9.50 per thousand cubic foot it would only cost about $150 to equal a ton of pellets.
For many of us natural gas is about as useful as nuclear fuel. If you don't have a pipe to your house you can't just go buy a drum of it.
Outdoor boiler with fan coil units inside ?
I thought about outside boiler stoves when I first build my other shop. I even ran pipping to the outside halfway from the shop to my house but never put one in. I don't think a 50K heat exchanger would do the job in my shop. And good luck in getting 50K BTU's out of one of those. Radiant heat is another matter, as another posted, it takes a while to warm up the floor but once it gets up to temp it takes very little to maintain. I wish now I had torn out that old slab and starting all over because I loved that heat system.
   / Thoughts on a pellet stove for a large shop #43
It really depends on your expectations. For my last shop that was uninsulated sheet metal, I had a big barrel wood stove with a blower fan. When I planned to work in the shop, I would go build a fire about 30 minutes before starting work. It would get the shop toasty warm even in single digit temperatures. Of course, as soon as the fire burned out, the shop was cold again. That was fine for my uses because I didn’t store any freeze sensitive materials inside and only cared about heat when I was working there.
   / Thoughts on a pellet stove for a large shop #44
In today's inflationary economy, no matter what you heat with it will cost more than previous heating seasons. NG included. We heat with propane in the house and also use a multifuel (pellet-corn stove) to offset the propane cost, but then I get my corn for free and 2 ton of corn and 2 ton of pellets lasts all winter for us.
I heat my shop with in floor PEX and a 40 gallon propane fired HWH and I keep the floor temp at 70. I use the multifuel stove in the shop to add to the warmth. 1 ton of pellets and 1 ton of corn lasts all winter out there.
I pre bought my propane for this year, glad I did as propane prices here are going up like a rocket ship. I own 3 500 gallon propane tanks and I'm starting this year with all 3 sitting at 85%.
I expect to use an additional 500 gallons this year which I pre bought this summer.
The house has a brand new Bryant Plus 95 condensing furnace in the basement as well.
   / Thoughts on a pellet stove for a large shop #45
They only come in 40 pound bags, not 50. 50, 40 pound bags to a ton skid.
Been heating my machine and fab shop with a multi fuel (pellet and corn) stove for years now as well as the house. Same units in each and I own a large woodlot and I am always culling trees from storm damage and I give away all the saw logs as well as everything 3" in diameter. All the rest gets roasted in the burn pile.
Having said that, I do have PEX in floor heat in the shop as well because no biomass stove will run longer than maybe 2 days with refilling the hopper so if I'm not out there, the PEX in floor heat keeps things from getting too cold. Only have propane here and normally, 2 500 gallon bottles at 85% full, lasts the entire winter.
Don't expect any biomass stove to be able to heat a shop (unless it's very well insulated and mine is), to a toasty temp, not gonna happen with a biomass stove that outputs only 85K btu running wide open.
Mine will hold the temp in the shop (20 x 40) at a comfortable level but certainly not at a sweat temp.
40 vs 50 wouldn't make a difference for my 95lb 4'8" wife. Also the bags are floppy, which makes them harder to carry.
I seriously considered it for a while, i liked the idea of filling the hopper and just setting the temperature and letting it go. But being the only one to be able to load it was a real deal breaker for me.
   / Thoughts on a pellet stove for a large shop #46
Actually my wife tends the one in the house, not me. I do clean it but far as filling it, I don't ever fill it.
What I have is... I have 4 large plastic trash cans on a skid (pallet) and when the last one is about 1/2 full, I tote the whole thing skid and all to the barn and I fill the cans in the barn. I take the trash can skid to the barn with the pallet forks on the tractor and return it to the area right in front of the steps going up on the back deck and my wife fills a 5 gallon bucket from the cans and fills the stove, I don't and never have.
Keep in mind that I also mix in dry corn as I dump in pellets into the cans as well. I mix the pellet / corn at a ratio of 3 parts pellets to one part corn. By doing that I don't have to deal with the corn clinkers that straight corn will produce. Basically, I do the mixing and filling of the cans and she fuels the stove.
In my shop, I have a single trash can that I fill at the same ratio because I don't consume as much out there as in the house.
I used to take a full ton skid and set it up on the deck and carry the bags in the house and fill it myself. Problem with that is, it the pellets get rained on outside with the overcover removed, the moisture finds it's way into the bags and ruins the pellets. All bags of pellets that I buy (I buy Michigan Hardwood Pellets), each 40 pound sack has a couple air holes in the top and rain water finds it's way in so I eliminated the issue and yes, either one of my tractors can easily lift a full ton skid up to deck height, no issue. Actually they can lift almost 2 tons.
Not buying any pellets this year because 2 years ago I did a bulk buy direct from Michigan Hardwood. I bought a full flat bed semi load, 44 pallets of pellets delivered to the farm and I still have 8 pallets left yet. I keep them inside the barn with the weatherproof overcovers intact and they are just as good as when I bought them 2 years ago plus buying in bulk and even with having them deliver them to the farm, they were pretty inexpensive than and extremely less expensive than they are today. Of course I had to unload all of them from the flat bed which was no issue either. I just had him pull into the drive next to the barn and I offloaded the semi with one of my tractors and the pallet forks.
The empty plastic sacks as well as the sacks I get my corn in either get burned in the ever present burn pile or go out with the trash.
I get my corn from the seed operation down the road for free. All I have to do is trundle down the road with the tractor and pick it up and it too comes on skids. I don't grow corn, never have but I have an ongoing source for it and it's free. They much rather I take it than them having to pay a tipping fee at the local landfill because the corn I burn is off grade seed corn that won't pass the customary yield test of 98% germination.
I realize that not everyone has the source I do, but I take full advantage of it and I need to go down the road and haul back 5 skids of off grade corn soon as it's sitting in the warehouse waiting for me to pick up.
   / Thoughts on a pellet stove for a large shop #47
Once you have hot water, you could use one (or more) in each area simply by teeing the lines. Of course you could get fancy and zone control them. Solves the heat problem and keeps the firebox out of the shop.
   / Thoughts on a pellet stove for a large shop #48
Here’s a comparison for the the various heating costs in NH. I have an addition that is heated with electric resistance and natural gas is unavailable so pellets stove was a no brainer. Fuel costs vary by region so you might have to adjust.
I do like the idea of not having to deal with all the trash that a wood stove creates. In my old shop I modified my old stove and extended the loading door through the wall in the shop to the outside where I built a lean to with a roof over it. I made that space big enough so that I could also keep about a weeks supply of dry wood in there in case the weather got really bad. That really helped especially during an ice or snowstorm. It really helped with the dust you get when opening and closing the feed door.
  • Good Post
Reactions: D&D
   / Thoughts on a pellet stove for a large shop #50
Keep in mind, there are three was to transfer heat.
Convection, conduction, and radiation.
Don't show us your blind spot.
Radiant heat may take longer to warm up, but it also takes less energy to maintain that same output. I can heat my shop with 70* water all winter and have everything inside 60*. I can open the doors for an hour and only drop a degree.
Why does radiant heat take less energy to maintain the same output? Please explain.
Eric
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
2025 Starvox SV-480 23HP Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple... (A59225)
2025 Starvox...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
PALLET OF 11 BARBED WIRE ROLLS (A58216)
PALLET OF 11...
2004 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2004 Ford F-150...
