Thoughts on 02 F450 dump
   / Thoughts on 02 F450 dump #31
I see it has had a plow on it, What is the front end parts looking/feeling like.
I see a lot of rusty trucks in Vermont that have plowed and sanded and by and large they have more ongoing work than I would want to do at any price.
This is coming from a long time plow truck owner who now uses a tractor for that job.
I will learn more about the front end when I drive it to my mechanic, and have the mechanic look at it, hopefully this week.
The only thing I can say it has going for it in terms of the front end, at this point, is low mileage.
   / Thoughts on 02 F450 dump #33
I would love to come across a dually truck with 4x4 from that era! I have a two wheel drive that I would love to change over to 4x4 so the shape of the donor body is of no issue to me, plus mine is also a 6 speed. I have a divorced transfer case I could use, but if I find an F350 like that, I won't have to figure out the missing parts! An F450 would work, I didn't want to have to change out my rear axle to match the front.
David from jax
   / Thoughts on 02 F450 dump #34
Imo The fact it's an f450 w 4wd is an added bonus even if it adds extra repair , maintenance costs. There were a few times I wish my rwd 3500 had 4x4, and a low range mine was also used for plowing and salting as plow and salt controls were just left mounted in it, I wouldn't be that apprehensive if it was me.
   / Thoughts on 02 F450 dump #35
If a low range is needed, a divorced transfer case added to a two wheel drive truck should give you that. My F350 in reverse is a little bit fast, and I have considered putting the transfer case in just to be able to go to Reverse in low range when backing a loaded trailer in a tight area.
David from jax
   / Thoughts on 02 F450 dump #37
David from jax
Makes sense thanks I learned something new, truck is long gone however if I ever find another underpowered 2wd dump truck I'll keep that option in mind.
   / Thoughts on 02 F450 dump #38
I also have found most plow trucks tend to be low mileage for whatever reason.
   / Thoughts on 02 F450 dump #39
I looked into farm tags but wouldn’t be able to get them because I’m not a “farm”. So annual registration will be a larger cost than insurance.
What are you waiting for? Become a farm. ;)
I’d be interested in anyone from PA on here that has gone through the farm tag process. I looked at the registration form but you need an EIN and to provide tax information (show income) on your farm. While we have a garden, orchard, timber, etc., we don’t generate annual income on our property.
Also, if I hauled a load of something for a neighbor or relative, technically I’d be in violation of motor vehicle code.
BARBED WIRE (A58214)
2020 Caterpillar 299D3XE High Flow Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
Deere 335P (A53317)
Deere 335P (A53317)
2005 Caterpillar 928G Articulated Wheel Loader (A55973)
2005 Caterpillar...
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
