those hyd connectors
   / those hyd connectors #1
dieselade
Bronze Member
west cent indiana
5225 & 3720
I have a 32o5 and a 4310. the loader was on the 4310 and went to put the loader on the 32o5 and the female hyd receivers are a different size. what a bummer that was/is...what is jd thinking?????my question is...what is the best way to handle this, get a new set of female recievers for the 3205 to match the loader male tips, or get new male loader tips to match the 3205?
   / those hyd connectors #2
You should change the smaller couplers to the larger size.
   / those hyd connectors #3
You may even be able to purchase adapters that plug between the 2 different sizes! In the farming world there is alot of different adapters for all types of different application. Of course anytime you reduce line diameter you'll reduce flow rate!
   / those hyd connectors #4
I'd go with Kenny's suggestion, especially if this is a permanent swap or you expect to do this swap frequently.
Make sure you have a drain pan and a couple plastic caps (to plug the hydraulic line when you remove the QD) handy.
Sakai SW880-1 (A47477)
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
2018 ASV Posi-Track RT120F (A47477)
2018 ASV...
KJ Portable Restroom (A53316)
KJ Portable...
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
