This winter will be cold at my place.
/ This winter will be cold at my place. #1
ToadHill
Elite Member
Catt county New York
Kioti DK35, Ford 8N, Oliver Cletrac
I just got a notice from the company I get propane from that I can lock in the new price for this coming year at only $2.70 per gal. Thats up 72 cents from last year or about 35% more.
For the last few years I've set the heat at the farm at 50 when I'm not there to keep the pipes from freezing, and it has still cost me over $1200 to heat the place over the winter. It looks like this winter I may not heat it at all, just drain the pipes, put RV antifreeze in the drains and toilets and not go out there again until spring.
/ This winter will be cold at my place. #2
I haven't called suburban propane yet but it looks like I'm in for it when I do. I might have to kick the pellet stove up higher instead.
/ This winter will be cold at my place. #3
do you have any windows facing south?
SOLAR HEATER
there are plenty of options that you can build using basically junk parts, just google on solar window heater and there are several modifications of the one built in the above link
hope this helps
/ This winter will be cold at my place. #4
Home heating kerosene is up by about 40% over here. If things dont change soon, old folks are going to be exposed to a very bleak, cold and potentially deadly winter. I heard on the radio this morning that they are expecting an increase in elderly deaths as a result of the increased cost of home heating.... That makes me sick. I dont want this to turn into another "price of oil rant" but.... the suits in wall street and in London are making billions in profits with their money games, and as a consequence, many vulnerable people will inevitably suffer as a result of these speculation wars....:mad:
If you have an elderly neighbour, keep them in mind this coming winter.
My recent price enquiry with my usual kerosene supplier, for 1000 litres of home heating kerosene.... @ €1.04 a litre = €1040 (or $1604usd):mad: :mad: :mad: how in the **** is an old person with limited means supposed to cover that (even with state assistance)??
/ This winter will be cold at my place. #5
propane the second most expensive thing to heat with .
Elcct. is first.
/ This winter will be cold at my place. #6
SOLAR HEATER
hope this helps
There is a lot of info online about making solar air/water heaters. This is my favorite using aluminum pop cans for the collector. I have been collecting cans for a year now and hope to build something soon.
A little back ground on pop can solar heaters.
Solar Air Heating
Build your own - step by step instructions.
sörösló by sztgyi
/ This winter will be cold at my place. #7
Boo. Electric is not the most expensive to heat with everywhere. Especially if you step into modern times and use electric to run a heat pump and extract energy from the air or ground for your heat.
Or better yet, get your axe. My heat is earned....
/ This winter will be cold at my place. #8
Nice looking wood pile!
So far I'm glad that I put in a pellet stove to get away from propane. With the price of fuel I am not looking forward to what the pellet prices are going to be this year.
/ This winter will be cold at my place. #9
nice looking wood pile.....
now, what would be the irony in using one of those old billboard tarps to cover it all.........the one i received the other day was an exxon mobile ad:D
i wish i could find something that "fit" me and i could beat the pants off of the system......
/ This winter will be cold at my place. #10
Well the propane dealer hit me hard. $3.17 a gallon this coming year. Looking for wood pellets tomorrow.
/ This winter will be cold at my place. #11
Good luck. I ordered my pellet stove in May (Harman). Dealer said he'll have it in a week. I waited and waited. At the end of July I called him and he said they are backordered until the end of September, but I am first on the list!
/ This winter will be cold at my place. #12
Why at set the temp at say 40 deg instead of 50 ?? 32 deg is freezing.
/ This winter will be cold at my place. #13
But , when the H.P. can't keep & those elect. elements come on ... get ready to spend some $$ .... If you can't install a groung source yourself. Get some $ ready... If you have gas & like gas . A 90+ furnace is the way to go
/ This winter will be cold at my place. #14
I'm glad I didn't run out and convert my work trucks to propane when I saw the news piece about the Swan delivery trucks running on propane. When they researched the article they were paying $2.30 for propane including road taxes.
/ This winter will be cold at my place. #16
I live in central Illinois and my lock in price for propane is $2.40 a gallon
Do you think you can save alot with pellets or corn stove.
I hate cutting wood.. I would have to install a stove,,,whats the pros and cons of corn or pellets
/ This winter will be cold at my place. #17
I installed a pellet stove about 4 years ago (3 winters). I have a propane central furnace (81% efficient) and a 2900 sq ft 2-story house. I have found pellets to be about 45% of the cost of propane on a BTU to BTU basis. I haven't had a propane fill in those 4 years, I was getting them monthly in the winter before that. Stove is in the living room which is open to both floors.
Downside to pellets or corn is:
1) work, you have to store the stuff, haul the stuff in to the house, fill the hopper regularly etc etc.
2) initial cost, I bought top of the line that can burn corn or pellets and spent $4,500 on my stove.
3) circulation, The first floor corner rooms are colder and we run fans all winter to move warm air into them.
Big pro to pellets or corn is the stove can run on a thermostat just like propane. Some people have mentioned that the newer ones can even regulate, when the room is warm they just turn way down and when lots of heat is called for they fire up to full. Mine is on/off from the thermostat and the level, low/med/high, is controlled by a switch in the stove.
Pellets and propane have gone up every year, so far the difference is still about 45% even though total costs have gone up. My stove will be done paying for itself this halfway into this next winter.
Being in the central states both corn and propane are cheaper where you are at. There are fuel calculators out there that can help you determine which is the cheapest heating source... at least for the fuel, installing a system could be quite expensive.
One of the calculators:
compare wood pellets natural gas propane and electricity
/ This winter will be cold at my place. #18
Charlz, the only problem with the chart you post is the variables of burner efficiency. They list the propane furnace at 80% efficiency. The unit I just had installed is 93% efficient.
/ This winter will be cold at my place. #19
Here is another that lets you set the efficiencies:
Fuel Cost Comparison Calculator
There are several out there.
/ This winter will be cold at my place. #20
Oooh, and be sure to consider duct losses. As much as 15% of the btus that those fancy 95% efficient furnaces make can be lost getting from the furnace to the rooms. A stove burning propane, wood, pellets, or whatever converts these losses to zero.
If I needed completely automatic heating then a propane freestanding stove could be vented through an existing chimney. Would be slick. They only get in the 80s for efficiency but they have no duct losses and most operate fully in a power outage.
TRACTOR FRONT GUARD & MISC (A63745)
TRACTOR FRONT...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
2004 VOLVO  L50D WHEEL LOADER (A63569)
2004 VOLVO L50D...
2006 Polaris Sportsman 90 (A64047)
2006 Polaris...
(10) 24' Free Standing Panels (A62183)
(10) 24' Free...
2020 John Deere 2633 Disk 29' 3" (A64047)
2020 John Deere...
