Third valve??
/ Third valve?? #1
blacktruck
Texarkana, TX
Cub cadet 2450, JD 420, Ford LGT18H
New guy here. Does anyone know if there is a third valve kit on the market for Cub/Yanmar tractors? I would like to add an angle capability to a snow blade or a thumb for the hoe. Any suggestions or first hand knowledge if this is doable? Or possibly who would manufacture or sell if available?
Thanks for the input.
Ken
/ Third valve?? #2
If you have an open center hyd circuit, then you should be able to install a valve in series with the flow and control a thumb or whatever.
A simple low GPM valve like this might work.
1 SPOOL 8 GPM PRINCE MB11B5C1 DA VALVE
/ Third valve??
Thanks J_J
It is an open center system. I've given thought to an electric solenoid so I could just add a button to the existing control but not sure yet. Time is limited for experimenting so I was hoping for a kit that includes all parts. The valve you mentioned is a thought if I can't find a kit. Not sure how it will work out but it just seems that an extra circuit would be better.
Thanks for the reply.
/ Third valve?? #5
Ken
Ken, do you know how close your system is to a John Deere? Kens Bolt on Grab Hooks has a very good price on a system for the JD models. :cool:
/ Third valve??
Thanks neighbor..
No idea but I will try to find out. In my mind it should be so easy to find a kit that has everything I need. Unfortunately I have not happened across it yet. Maybe that is just wishful thinking on my part. I'll check the link.
Thanks for the tip.
Ken
/ Third valve?? #7
blacktruck,
A 3rd function valve is just another valve to control a cyl or motor. You could have one, two or three of these valves in a circuit, or you could have three valves in a block joined together.
The valve you are looking for is simply a solenoid valve designed to control a cyl.
You select the valve based on the GPM flow, port size and functionally.
Most of the valves sold are very similar, and the add on parts fit a certain tractor.
Any valve that meets your specs as to GPM, port size, etc that will control a cyl will work.
You simply add the hoses, fittings and wiring and switches to make it work.
It would be installed in series with the flow path after the loader valve.
/ Third valve?? #8
Thanks neighbor..
Thanks for the tip.
Ken
Think about what you are asking for. You want a company to either purchase or rent every tractor that there is so that they can produce a nice clean 100% complete 3rd function kit that they might sell a few kits for. Simply is not cost effective even if it were possible. For a few of the most popular models I could see this being done by larger companies.
Other than that, either the order needs to be done with input from the customer up front or a 2 stage process as others might do.
Good luck with your project. ;)
/ Third valve?? #9
The tractor side is VERY close to JD, but the FEL is completely different I think. A diverter setup would be the easiest to install, and probably the cheapest as well.
/ Third valve?? #10
Yanmar, does show a optional third function for there LX hydro units. Try googling Yanmar third function , should give you some ideas.
/ Third valve??
I do understand the manufacturing process pretty well as I work for a rather substantial one here.. I know it isn't feasible to make one for every application. As much as I think it should be out there....pretty sure it isn't. Mostly looking for experienced users that have already went down that row of adding one. I am thinking now about adding the fittings between the tractor and BH fittings. Make it live all the time and just add another control valve somewhere. That would allow me to use a thumb or a power angle on a rear blade or a grapple on the FEL.
All good conversation here folks. Precisely what I was hoping to find on this.
Thanks all....
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
PALLET OF CUT-OFF VALVES (A67714)
PALLET OF CUT-OFF...
2006 Volvo VNM T/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM T/A...
2007 Toyota Rav4 SUV (A66738)
2007 Toyota Rav4...
2008 Sterling L7500 Series T/A Vactor 2115-J6 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
