Third function
   / Third function #11
Not sure yet on the Third function while lifting & curling bucket. I have purchased a grapple yet. The problem I was having was after the install I couldn’t lift & curl at the same time. But like I said, that was due to a cold tractor at idle. I’m sure once put a grapple things will change. I was more concerned of just my lift & curl.
Waiting on a Ag auction soon to come up to find a Grapple
Used Grapples are hard to find. I sure wouldn't sell mine. Hopefully you can find one.
Understand that your tractor has a maximum flow capacity on the hydraulics. Using one function, such as "lift", it will produce a certain speed. Add "curl" while lifting and the speed will slow because it's being split for two functions. Add 3rd function (if you have true 3rd function) while lifting and curling and the speed will slow again because it's now being split for three functions.
It's common on smaller tractors that they will not produce enough flow to effectively run all three at once. Nothing you can do about that issue.
   / Third function #12
Some loader valves, like the one on my Branson, dump all flow to the tank when any spool is operated. This makes the bucket dump quickly and the loader drop fast when you lower it. It also means that any valve plumbed after the loader, on it's power beyond, will see no flow when the loader is operated. So you can't operate a 3rd function or a rear remote or the 3pt hitch while operating the loader.
1986 Ford LNT9000 Dump Truck (A56438)
1986 Ford LNT9000...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
