Third function valve kit
/ Third function valve kit #1
coolbrze
VA
Kubota MX5800
Adding an EA grapple to my MX5800 & need a 3rd function valve kit. Who makes a good solid kit that you'd recommend?
/ Third function valve kit #2
We sell tons of these custom 3rd function kits by WR Long and guys love the fit and easy install. Everything needed is included and the couplers are compatible with our grapples!
You'll find over 225 customer reviews on the website and get $50 off when you order it with a Wicked Grapple!
Travis
/ Third function valve kit #3
I got my 3rd function kit from everything attachments. WR long is the brand. They sell kits that are model specific if you call them have your tractor and loader model #'s handy. The kit for my kubota was very easy to install and comes with directions, did it in less than an hour. Comes with all hoses and couplers too.
/ Third function valve kit #4
I just installed a WR long kit from EA last weekend on my L4701. Very easy install even with the backhoe. All fittings were correct and straightforward. I ordered it with my grapple and the kit shipped separately. I was able to install it before my grapple was shipped.
/ Third function valve kit #5
I bought the kubota kit for mine. There was about a $25 price difference but I liked the kubota kit because the bracket was different and the valve didnt stick up so high and also I can easily source replacement parts for it from multiple sources
/ Third function valve kit #6
I'm not impressed with the Land Pride/Kubota kit when it comes to routing on MX series machines, but it could be better for other tractor models.
Travis
It just seems poorly planned to me...
/ Third function valve kit #7
W&R Long 3rd function valve kit on my MX5800:
Easy 90 minute install. Works well and no complaints. I also installed one on my L6060.
I bought a WR Long 3rd function kit through EA when I ordered my grapple, thanks Travis. For those of you installing yourself, how difficult is it? Had one Kubota dealer quote me $380 in labor because "the MX5800 does require wheel removal to access the power beyond set" whatever that means. Are there instructions that come w/ the WR Long kit? I'm only semi-mechanical but if it's easy, it's easy. Thanks for the help so far!
/ Third function valve kit #9
It does come with some instructions and I've never heard of anyone having to remove the wheel to install a WR Long kit.
This isn't an MX, but it is a quite informative video by one of our customers.
Travis
/ Third function valve kit #10
You can fab a diverter valve setup for less than$300 with a little planning. I like the simplicity of a single momentary switch to use the curl function for the grapple clamp.
/ Third function valve kit #11
The dealer installed my land pride third function valve, all wires are hidden, and all hyd lines are tucked nicely out of the way. However I have seen some on this forum that are not protected. Good luck with your install.
/ Third function valve kit #12
My bought mine from Construction Attachments, also in NC like EA.
I wish I had bought the kit from EA. :(
/ Third function valve kit #13
Just like nbking - I had the dealer install my W R Long valve kit and grapple. Everything is on the inside of the FEL arms and protected from limbs, roots, stobs etc. A couple of pics will explain. Everything is either between the FEL and tractor body or covered by that "shield".
View attachment 593709View attachment 593710
2022 EZ-GO ELITE...
20' One-Trip Shipping Container (A66285)
20' One-Trip...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
2023 Blue Diamond 103030 Extreme Duty Cutter (A65640)
2023 Blue Diamond...
New Holland TC29 Farm Tractor (A65579)
New Holland TC29...
