Third function switch or button source?
/ Third function switch or button source? #11
LVA17501 Harness,wiring, 3rd eh $51.18
LVU16701 Grip, outer $16.88
LVU16650 Grip, inner $03.45
And a few misc nuts and screws Got these parts in my JD parts cart and these are the prices reflected
Pictures please, so that everyone can see the style that it is.
Thank you. ;)
Definitely pictures please.
/ Third function switch or button source? #13
I'll have to look that up.
I wounder if that wiring harness includes the actual switch?
/ Third function switch or button source? #14
I dont think i can get the pics off of JD but if you look up the part no it should show you a pic of it
/ Third function switch or button source? #15
For those without JDP access, here is a good breakdown of the parts: OEM Parts
That is a little different than mine in that it only has two switches in a rocker configuration whereas mine also has a third that I used for a horn. These are just membrane switches, so the use of relays is absolutely needed, and the wires are only about 18" long. I also had to machine an adapter to make it fit my handle. So, while is does appear cheap, it's not quite a plug-n-play setup either.
Thanks for the link and the pics. Your install looks good, I didn't notice the link before to your pics. That grip looks like it would work good. I think I'm going to have to find one I like soon.
/ Third function switch or button source? #17
I just ordered one for my tractor.
Here's all of the part numbers and prices...free shipping.
I even ordered all of the screws. It was less that $72.00
Kubota wants $190 for the Grip and switch.
/ Third function switch or button source? #18
PLease let us know how it goes;Want to do mine soon as the extra cash comes along,. Going with JD lines down the loader frame and 12 v valve with the switch you ordered and then I will build a root grapple for my JD 4300
/ Third function switch or button source? #19
Here is a drawing from JDFparts, parts 1-7.
/ Third function switch or button source? #20
Have you received the parts? If so, a couple of questions:
How many wires, type of connector?
What is the diameter the grip fits?
Thanks!
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
Manitou MHT 10230 50k lb. Telehandler (A60352)
Manitou MHT 10230...
2022 DODGE RAM 2500 SERVICE TRUCK (A60736)
2022 DODGE RAM...
2014 Chevrolet Silverado1500 Pickup Truck, VIN # 1GCNCPEH0EZ393232 (A61165)
2014 Chevrolet...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
Case CX36B (A60462)
Case CX36B (A60462)
