Third Function Switch for FEL Joy Stick
/ Third Function Switch for FEL Joy Stick #11
JJ,
Have you used or seen used any of those. I have perused that list before with poor results. See my last post to Paul on my rational. I know folks like JD, Fit-Rite, Everything Attachments, and LP buy those from some US supplier probably. It is easier to either see one over the counter or discuss with someone you can communicate with before you buy something that won't work. I am now really thinking an all hydraulic solution and leave the switch/solenoid system alone. Space for hoses seems the same either way, just have to continue the PB circuit back to the 3 PT as it is next in line on my BX. A valve block is equal in price to a solenoid just mounts in a different place.
Ron
Ron
Do you have a JD dealer close by? I know that a lot of the tractors are now coming std with the grip, just blank with no switch. All you need to do is look at a tractor that has that grip, shouldn't be a big deal. The JD grips do seem to be a VERY good deal. :cool: As long as it is comfortable for your hand, you would be all set.
My grips come from Scorpion, most people find them to be comfortable, but they are more $$ than the JD grip. :(
Manual valves may be the way to go if you are adding multiple sets. All personal preference though. ;)
/ Third Function Switch for FEL Joy Stick #12
This is what I ordered for my L4240.
I did have to machine a bushing to adapt the JD control handle to the Kubota 13mm loader shaft.
The JD handle is nice ergonomic design.
You will need to use relays since the handle switches don't have a high amperage capacity.
There is another part number for the wiring harness that allows use of the third button on the control handle, but is quite a bit more expensive.
I have the same-but the more expensive ($170) version since I bought mine before they where being used on the CUT's (mine was for the 110TLB's).
Like you wrote, you have to be able to machine your own bushings, and be able to wire up the relay(s) since the membrane switch is not rated for the current draw of a solenoid valve. My third button operates a horn. This handle is super comfortable.
Here is the thread I did one my install: http://www.tractorbynet.com/forums/customization/110476-joystick-handle-horn-install.html
2014 Ford Fusion SE Sedan (A59231)
2014 Ford Fusion...
STEPP SEALCOATING MACHINE (A59906)
STEPP SEALCOATING...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2013 Ford Edge Limited AWD SUV (A59231)
2013 Ford Edge...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
