Third Function Switch for FEL Joy Stick
/ Third Function Switch for FEL Joy Stick #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
There has been a lot on interest here lately on setting up a 3rd function on FEls to operate a grapple, including me. I cannot afford to buy a manufactured grapple unit so am designing one I can fabricate in my shop. Question for all you experts: Who makes those fancy switch units that fit over the joy stick? If I go with the solenoid option that is the only puzzling part of the puzzle. I am also considering a hydraulic manual valve set up. I would pick up the P, PB, and T connections at the FEL joy stick valve connection points.
Ron
/ Third Function Switch for FEL Joy Stick #2
Ron
Brian at fit rite can fix you up
valves
/ Third Function Switch for FEL Joy Stick #3
Ron
Those ready made handles are nice, but expensive.
If you have a wooden or plastic or even metal knob/handle, cue ball etc,, then machine or cut out a hole for a waterproof switch and save a bunch.
/ Third Function Switch for FEL Joy Stick #4
This is what I ordered for my L4240.
I did have to machine a bushing to adapt the JD control handle to the Kubota 13mm loader shaft.
The JD handle is nice ergonomic design.
You will need to use relays since the handle switches don't have a high amperage capacity.
There is another part number for the wiring harness that allows use of the third button on the control handle, but is quite a bit more expensive.
Paul,
Is there a brand name other than JD on that switch? JD buys them from somebody and marks them up from 50-100%. I hate to buy this type item on line as it is so hard to be sure it will work. There is a lot of stuff on line but hard to decipher what is made to fit a hydraulic valve handle and what is just a switch. Joy stick switches are used all over industry. A lot of the companies are foreign and it is difficult to find their US distributor. I really want to see one at the counter and determine its feasibility.
Ron
/ Third Function Switch for FEL Joy Stick #7
Paul,
Ron
Go to Fasse websight and pick the one you want... search for dealers on their site.
/ Third Function Switch for FEL Joy Stick #8
Paul,
Ron
No other brand name on the switch.
For the price I thought it was a good deal.
Most all of the other control handles with switches are over $100.00
And the grip is a really good design.
JJ,
Have you used or seen used any of those. I have perused that list before with poor results. See my last post to Paul on my rational. I know folks like JD, Fit-Rite, Everything Attachments, and LP buy those from some US supplier probably. It is easier to either see one over the counter or discuss with someone you can communicate with before you buy something that won't work. I am now really thinking an all hydraulic solution and leave the switch/solenoid system alone. Space for hoses seems the same either way, just have to continue the PB circuit back to the 3 PT as it is next in line on my BX. A valve block is equal in price to a solenoid just mounts in a different place.
Ron
Ron
/ Third Function Switch for FEL Joy Stick #11
JJ,
Ron
Ron
Do you have a JD dealer close by? I know that a lot of the tractors are now coming std with the grip, just blank with no switch. All you need to do is look at a tractor that has that grip, shouldn't be a big deal. The JD grips do seem to be a VERY good deal. :cool: As long as it is comfortable for your hand, you would be all set.
My grips come from Scorpion, most people find them to be comfortable, but they are more $$ than the JD grip. :(
Manual valves may be the way to go if you are adding multiple sets. All personal preference though. ;)
/ Third Function Switch for FEL Joy Stick #12
I have the same-but the more expensive ($170) version since I bought mine before they where being used on the CUT's (mine was for the 110TLB's).
Like you wrote, you have to be able to machine your own bushings, and be able to wire up the relay(s) since the membrane switch is not rated for the current draw of a solenoid valve. My third button operates a horn. This handle is super comfortable.
Here is the thread I did one my install: http://www.tractorbynet.com/forums/customization/110476-joystick-handle-horn-install.html
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2022 EZ-GO ELITE...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
2019 FORD F-350 SUPER DUTY (A65643)
2019 FORD F-350...
2014 KENWORTH T370 ROAD TRACTOR (A65054)
2014 KENWORTH T370...
