Third function remotes: requesting pics of controls
/ Third function remotes: requesting pics of controls #1
AllenArmory
Lavon, Texas 75166
TYM T554HST Cab
I'm buying a new tractor (TYM T354HST) and the dealer will add a third function remote for me to power a grapple. I assume the hydraulics part is fairly standard, but the loader joystick that's replaced seems to vary in quality and ergonomics. Do any of you have any recommendations on what to use and what to avoid? Pictures would be most helpful.
Thanks!
/ Third function remotes: requesting pics of controls #2
I am fairly sure that your tractor comes with a TYM control grip already on the joystick, switch should be in it, just needs to be wired into the valve. Look at the far right hand picture and you can see a button in the grip.
The joystick has one button on it already, but I don't think it's for the 3rd function hydraulic. My understanding is that that the 3rd function kit includes a new joystick that has the open/close buttons (for grapple functions). I'm asking for pros/cons on the various 3rd function controls.
If I'm asking the wrong questions, I apologize, since I'm very new at this and don't even own a tractor yet. Please educate me if I'm using the wrong terminology or my understanding is not correct.
/ Third function remotes: requesting pics of controls #4
You are right if there is only a single button, then the factory grip could only be used for a diverter type 3rd function, not for a true 3rd function. A true 3rd function requires 2 switches, so either a rocker type switch or 2 separate buttons. I can provide either in the grip shown for about $200. A complete kit runs $750.
Can you post a picture of the rocker type switch?
/ Third function remotes: requesting pics of controls #7
All the rocker is, is a cover glued over the 2 separate switches. I recommend going with the 2 buttons with this style of grip.
/ Third function remotes: requesting pics of controls #11
Ok, I just spoke to my dealer and he told me he found out that the TYM grip (with the single button) does support the 3rd function kit. He said that pressing the button will open the grapple and pressing it again will close it. I was assuming that two buttons were necessary, but apparently that's not the case.
Thanks for all the replies, especially MtnViewRanch. If I ever decide I don't like the TYM grip, I'll definitely consider the Scorpion grip.
I forgot about this post, so I'll have to contact my dealer to clarify.
Yes, in my opinion. I'm sure the quality is fine, but I don't like the look of the plastic, the rough edge on the bottom and the two large bolts on the side holding it to the joystick.
/ Third function remotes: requesting pics of controls #16
I have WR Long 3rd Function kits on two tractors. The control handle look great and works great! Anything but cheap? The handle is black, not gray as it looks in WRL picture. The bolts are of no consequence, keeps control handle firmly attached.
Cosmetics of the handle are a silly issue, it's how well the 3rd function works. The WRL rocker switch is well placed to operate with your thumb while operating FEL with same hand. I wouldn't have bought a 2nd one if first one didn't work well!
2017 Ford F-250 Pickup Truck (A61573)
2017 Ford F-250...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
17395SFL (A61568)
17395SFL (A61568)
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2019 FREIGHTLINER 122SD 6X4 T/A TRUCK TRACTOR (A59912)
2019 FREIGHTLINER...
213090 (A64276)
213090 (A64276)
