sriddle1
- Joined
- Apr 2, 2014
- Messages
- 212
- Location
- SW New Hampshire
- Tractor
- ACTIVE: JDX730 DAYS GONE BY: JD3010, JD790, JD425
Good Morning, Picked up a used 47-In 2-Stage Snow blower coming off a JD425 with all the mounting hardware for my JD425, to date I've only used it for lawn cutting. To lift the lawn deck I simply lift up on one of the two Hydraulic Control Levers that actuates the lift linkage. The 47 Snow Blower has (4) hydraulic lines, the SCV is located under the left footwell and currently all 4 ports are plugged, never used, and that's where I'm at. I'm looking for the parts to connect this up...... The SCV....... I'm thinking (guessing at this point) I need (1) "Dentent Kit" AM128927 for each of the (4) plugged ports ???? Now about the Hydraulic Control Levers, I'm assuming after I connect all (4) Snow Blower Lines, one of the Hydraulic Control Levers controls Lift/Lower, the other controls Chute left/right. The deck lift linkage piston, seems I need to disconnect that since one of Hydraulic Control Lever controls that Piston..... Maybe ???? Just want to be ensure I have everything set-up for winter, no surprises..... Thanks for any assistance,
