Thinking About Log Length Firewood
   / Thinking About Log Length Firewood #31
I always cut mine in 8 ft lengths and would pile it up when i figured i had enough which was about 10 full cord.I would setup the saw rig and cut it up.
   / Thinking About Log Length Firewood #32
I have been thinking about buying log length firewood. I could get easy delivery and off-load at the bottom of my hill, but after cutting would have to haul up the hill to split and stack in the shed. Also, I would need to rent a splitter once a year for about 3 cords at a time.
What is your experience? I have cut a bunch of logs that I skidded out of the woods but ran out of that supply. I only have the tractor bucket and chains to move the logs around. What is the best way to manage cutting a stack of 6 to 10 cords of log length?
Just yank 'em up the hill to where you process them. Most log loads here in ME are pretty small (logs) with a 16" being on the big & rare side (for size). Even with your smaller tractor you should be able to pull them one at a time from the pile with a chain, get it to where you can short chain it, and if you don't have some sort of hitch on the 3pt to raise it off the ground, use the bucket and back up. A log dragging on your new driveway will not harm it if properly compacted, but might end up with a little bark ground into it that will come out. Avoid dragging the log on the edges of the pavement.
Be careful around your log pile, they can all of a sudden shift and roll out flat when disturbing it. No harm done, just be aware of it and don't leave a saw or worse, a helper stand to either side of the pile while dragging the logs out of it.
edit; where your chain is attached to the log WILL mess up your pavement. Raise it off the ground.
   / Thinking About Log Length Firewood #33
The front end of the tractor can sure take a beating that way!.
I use the tongs on the loader to lift big rounds up on to the splitter. That's banging around enough!
Actually, the butt of the log never gets near the front end or grill guard. The log is lifted so 6" to a foot of the butt is sticking out toward the grill guard front of the tractor. The lugs (actually short lengths of welded re-bar) holds the log in place. With proper ballast it can lift a 16' length of 30" green eucalyptus. Any longer or heavier and it is cut to 8' for loading.
I take the 16' lengths home from the wood lot on an 18', 7000 lb Big Tex diamond plate car hauling trailer. The same log carrier is used to load the trailer. It doesn't take too many logs to overload the trailer but is only pulled at 5 mph max down the road with the tractor.
As already stated, standing straight up while sawing the log into rounds is a breeze. All the rounds end up in a pile waiting for the splitter to do its work.
Here is a photo of my smaller L3650 (since sold) when the logs were chained to the bucket for cutting. Same idea, just a smaller tractor and smaller log. I call it the "narwal look".
   / Thinking About Log Length Firewood #34
I have pallet forks for my 3 pt. It is easy to back-up under big logs and smaller ones I can pile on top. A couple of straps and i can haul a half a cord out of the woods in one load. Get to where I am cutting it and leave the straps in place and start from the outside in. The logs are held secure and off the ground and makes it really easy to cut a lot very quickly. I just have to watch the front bottom one because it is next to the toolbar but a couple of cut pieces to space it away solves that problem. This is hte least handling i know of.
   / Thinking About Log Length Firewood #35
Yeah, that photo shows a small load. I was hinge cutting and accidentally cut one all the way down so I carried just that tree out. However, I can get 5-6 10" logs in there. I cut them at 9' and carry them out of the woods through hilly terrain. I usually never get off the tractor, just grab and go. No lashing the load. I'm thinking the grapple gets them out easier and faster.
Ummm, having used both forks and a grapple to move logs, I can assure you that the grapple is far faster. With forks, you have to be balanced very close to the Cg of the log to make it work. Much less so with the grapple, though that does also make you more careful in transport as you can get tippy if you are too far off. I never was able to just lift a log with forks and drive away (for the most part). Always required adjustments to keep it balanced. Never an issue with the grapple, and I can just grab a log or two and go without getting off at all. Dismounting to futz with stuff is the biggest time killer I have run into.
Dan, maybe you are God of the Forks, but I sure wasn't...the grapple fixed all that.
Just takes practice with the forks. Moving wood is easy. I bought the forks to move cubes of bricks we had from building our house. The cubes needed to be moved which require pallet forks. The forks are JUST small enough to fit inside the "tunnels" in the brick cubes used to pick up the mass. The forks have to be aligned just right in three dimensions or bricks will be broken or pushed out of the cubes. I broke and pushed out a few bricks but I learned real quick on how to get things aligned just so. Some of it is by feel too. Moving logs is easy peasey.
A tree in the woods seldom falls where it is easy to get the tractor. Usually, for the larger logs, say the first six logs from the stump, I can get get the tractor in to load the loads on the pallet forks without having to leave the seat. The first few logs from the stump I might only be able to get two or maybe three logs on the tractor before hitting weight issues. The last few logs I can get more on the forks but then you get into the smaller logs from the tree tops. Those logs simply have to be manually loaded. No way to get to those logs without moving them by hand first. If I thought a grapple would help, I would go buy one. Right now I have a mess to clean up from trees we had bulldozed down. A grapple would be better than my 4n1 bucket but not that much better to justify the cost since I will only have to make a few more trips with the 4n1 vs the grapple.
I cut my logs into 6 to maybe 9' feet which is very easy to balance on the forks. I can't go much bigger since that would make it harder/impossible to drive out of the woods. The biggest time killer for me is running from the location of the downed tree to where I split store wood. Transporting the logs is what takes time. Getting off the tractor to load logs that have to be manually moved anyway is nothing in comparison to moving the logs from point A to B. I am all about saving time, since I don't have much time to get chores done, if I thought a grapple would be more efficient I would buy one ASAP. For me, the pallet forks works much better for moving logs AND I can use the forks to get palletitzed stuff into and out of the truck.
Later,
Dan
   / Thinking About Log Length Firewood #36
Aha! We have a difference of opinion as to what construes a "log"! I would agree that using forks on such short logs would not be all that bad. You set the forks wide and you are only hanging over a couple feet at most. In my definition, a log is basically a whole tree or maybe half or third of it (depending on how massive the tree is). Almost impossible to get perfectly balanced on forks. With the grapple, that is much improved. Sure, you cannot be waaay off center or you will cause all kinds of other problems and potentially tweak the grapple or loader or even tip the tractor, but it allows you a lot of flexibility. When you have something sticking out 10' on each side of the grapple or forks, it gets a lot more interesting... Now I see where you are coming from.
   / Thinking About Log Length Firewood #37
I cut most of mine 8-10' lengths as well, and haul out on pallet forks. If you cut much longer, you spend a whole lot of time manuevering around other standing trees.
For sawmilling, I do cut them 8-20', but then I skid out with a rear mounted winch. Often, I'll have both smaller stuff on the forks and dragging a larger log behind.
ry%3D400
UPDATE: I did in fact buy a truckload of log length wood, delivered yesterday. The driver delivered them to the flat area at the bottom of my hill where I have access all the way around.
He put the pile on runners to keep them off the ground. My plan is to cut/split/stack at least half of the 9 cords this spring, and do the rest in the fall/winter.
My wood for the winter of 14/15 is already put up and seasoned and dry, so this puts me 3 years ahead of the game.
My motivation for doing this was the cost of propane going up, and lately it has been hard to find wood delivered under $245 a cord green. So now, I feel like it's money in the bank. I need the exercise too.
Oh, and I just sharpened my 5 chains on my new Chicago Electric chain saw sharpener from Harbor Freight. It clearly is not a commercial grade tool but it seems it did a good job, I will know soon how well they cut wood.
   / Thinking About Log Length Firewood #39
What did you pay for that 9 cords? What do you call a cord?
   / Thinking About Log Length Firewood #40
In Maine (where the OP is) we call a cord 4' x 4' x 8'. I have never seen other colloquial terms used like "face" cord or "rick".
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A57453)
2004 International...
Laymor Sweeper (A57453)
Laymor Sweeper...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
3 Point Boom 5ft (A57454)
3 Point Boom 5ft...
