Thinking about a 1710
   / Thinking about a 1710 #11
AndyMA said:
Actually Rick, I was refering to a 1710 that I had before the 2120. Maybe I was just stronger back then !!!
Andy
Yes, I knew you were referring to a 1710 you once had. I thought a comparison of that to the 2120 I also remember you have/had would help make my point. The 10 series power steering generally requires more effort than just about anything with fully hydrostatic steering.
Buts its still a step up from my Bolens which is completely manual steering.
   / Thinking about a 1710 #13
No doubt
Andy
   / Thinking about a 1710 #14
Hello, I have a 1982 FORD 1700 that is in Like New Condition 4x4 with Ag tires,the tractor has 550 hrs & the tires are excellent. I am looking for Turf Tires & a Ford (770) Loader for my Ford 1700 2 cyl. Diesel tractor.
If ANYONE Knows of a Loader for sale that will work on my tractor please call me after 7:pM any night at 631-757-9490 .Thanks......Chris ,(from L.I. New York). However I do go Upstate N.Y. to the Delhi Area frequently.
   / Thinking about a 1710 #15
Chris,
I have looked around and searched for a 770 loader for my Ford 1700 to no avail. They will not part with the loader if the tractor runs and have not been able to find a dead 1700 with a loader to salvage. Since you have 4x4 and may be power steering might not be a bad idea to invest in Koyker for 1700. They are good loaders and probably installed will cost you $2600-$3000. 155 size Koyker with 1 3/4" cylinder and Ford mounting bracket in Ford blue should fit the bill.
JC,
Koyker Manufacturing
   / Thinking about a 1710 #16
Chris
Depenping on what you are planning on using the FEL for you should take a look at the flow rate of the hyd. pump on the 1700. The FEL will have power but it will be kinda slow. If you are expecting the hyd. to be fast like a skidloader you will be sadly disapointed.
Bill
   / Thinking about a 1710 #17
I have a 1985 1710 2wd with a SMC84Q,which Ford dealer was using quite frequently for new tractors of that era. Alamo owns them now,but anyway, I saw one on ebay last week that went for $750.Be patient and you'll find what you want.I was at the right place at the right time and got my setup for $1500.I feel guilty...NOT!!
Chris,
JC,
   / Thinking about a 1710 #18
Welcome to TBN Blue,
I'm glad it worked out for you. What I have is time, if I find a good one will pounce on it. I find my best deals when I'm not looking for it and stumble right on it. I would consider an old loader around $1000 with some repair work but even with beat up loaders people expect to sell for 80% of original value:rolleyes: If I move and build on my acreage a shiny brand new beast with a loader and some bells and whistles is going to be on the agenda:D
JC,
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2022 John Deere 5055E (A60462)
2022 John Deere...
