Things I can do with my tractor
   / Things I can do with my tractor #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Where can I learn about the various implements I can attach to my tractor.
Ive read here that since I have a 3 point system just about all implements are universal in that they will work with my tractor. Is this true?
Ok so what is avail implement wise that I might start looking for on Craigslist?
I have 5 acres I am working on developing for my future home build. I just bought a Kubota 6100E which unfortunately is 2wd and no front bucket.
Just seen tonight online where there is evidently some type of scraper that might help me to level some areas of my property. This would be nice to have but I know nothing about this and other implements like this so where do I learn?
Thanks
   / Things I can do with my tractor #2
Congrats on the tractor. That's an oldie but goodie. :)
Used implements can be hard to find and almost as expensive as new, but check Craigslist and local auctions.
Since you're in Florida maybe your soil is pretty sandy, in which case you might be able to use a "chain harrow" (an inexpensive implement) to do some smoothing. Many folks just drag an old metal box-spring behind the tractor to smooth out the surface.
But "leveling" will need an implement with more weight and ability to cut through the soil. I'm guessing your tractor won't take an FEL or that it would cost a lot to add. Cheapest would be a simple rear blade. Next cheapest would be a box blade. Look on YouTube for videos of the various implements in operation to see what they can do.
About the only used implements I see for sale pretty cheap are old farming implements like harrows and various plows. Maybe something like that could be useful.
   / Things I can do with my tractor #3
Here is an 75% complete implement listing.
http://www.lsuagcenter.com/~/media/...aa214276e14dacb/pub2917tractorimplements1.pdf
Some Category I implements will fit your Three Point Hitch. Many will not due to small dimensions of the hitch on the tiny tractor. If the two Lower Links contact tractor rear tires when spread, if may be possible to set your wheels/tires wider.
You will be able to pull a Chain Harrow for sure, which is good for leveling over a long duration and many passes over the ground. Chain Harrows have varying abrasion qualities, depending on which side is UP and which end is nearest the tractor.
MORE: https://www.tractorbynet.com/forums...c-countyline-tarter-boom-pole.html?highlight=
Buckeye tractor make an assortment of implements sized for <25 horsepower tractors.
LINK:Buckeye Tractor Online Catalog - Garden Series Page 01
Tractor will be limited by its light weight, being 2-WD and 400 pound lift capacity of the Three Point Hitch.
Hey, it is a tractor. ENJOY.
Kubota B6100
1978 - 1984
Sub-Compact Utility tractor
Manufacturer: Kubota
Variants:
B6100D: 4WD
B6100E: 2WD
B6100HST: hydrostatic
Kubota B6100 Engine:
Kubota 0.7L 3-cyl diesel
Kubota B6100 Power:
Engine: 14 hp [10.4 kW]
PTO (claimed): 12 hp [8.9 kW]
Capacity:
Fuel: 3.4 gal [12.9 L]
3-Point Hitch:
Rear Type: I
Rear lift: 400 lbs [181 kg]
Power Take-off (PTO):
Rear PTO: transmission
Rear RPM: 540/750/1000
Front RPM: 2800
Dimensions & Tires:
Wheelbase: 48.9 inches [124 cm] (2WD)
49.1 inches [124 cm] (4WD)
Weight: 970 to 1036 pounds
Front tire: 4.00-9
Rear tire: 7-16
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: manual
Brakes: differential mechanical shoe
Page information:
Last update: September 25, 2015
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
   / Things I can do with my tractor #4
I need to haul wood. I am hope there is a trailer that will somehow bolt to the tractor.
You need this type of adaptor for the Three Point Hitch.
VENDERS: TRAILER HITCH TRACTOR DRAWBAR THREE POINT KUBOTA handi | eBay
You need one sized for the Kubota BX tractor. It should fit yours.
You need a 20" (+/-) width, NOT 28".
Lowe's, Home Depot, Rural King, Tractor Supply Company all sell small trailers with 1-7/8" ball hitches. I like the Polar dumping poly trailers.
Shop via web pages.
LINK: Dump Carts - Riding Mower & Tractor Attachments - The Home Depot
A reduced size MIDDLEBUSTER will loosen soil for the CHAIN HARROW.
King Cutter XD model (red paint, not yellow paint) reduced size MIDDLEBUSTER is one option.
LINK: XB middle buster implement - Yahoo Search Results
Dirt Dog also sells a reduced size MIDDLEBUSTER/LAYOFF PLOW
LINK: Dirt Dog Manufacturing >> Disc Harrows Tillage - Compact Lay Off Plow
VIDEOS: TRACTOR MIDDLEBUSTER - YouTube
https://www.youtube.com/watch?v=Af6CLsASvm0
   / Things I can do with my tractor #5
Thank you for your time
   / Things I can do with my tractor #8
LOT OF 12' FLAT IRON (A58374)
LOT OF 12' FLAT...
Massey Ferguson 9250 (A56436)
Massey Ferguson...
2020 Am-Tank 800 Gallon Fuel Tank, S/N 73348, Nominal Capacity 838 Gallon/3172 Liter w/Spill (A59076)
2020 Am-Tank 800...
EDGER & FRONT TINE TILLER (A58374)
EDGER & FRONT TINE...
Tiger Mowers Mulching Head Attachment (A55973)
Tiger Mowers...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
