thickest 2x2 square tube to fit receiver hitch
   / thickest 2x2 square tube to fit receiver hitch #31
Yep. It's that inside seam that is hard to deal with. :)
2" square tube with less wall thickness, I can't remember if it's 3/8 or 5/16, will slide inside a 2&1/2" outer tube with 1/4" wall thickness if that would work for the application. It will be a little loose but when I built a bolt on grapple with an adjustable mount I drilled and welded a nut on the outer tube to run a bolt through and tighten it up.
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A58018)
2020 INTERNATIONAL...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
